Should I upgrade to 2 bbl carb??
Discussion in 'Parts Interchange' started by Comet4me, Oct 5, 2014.
  1. 71gold
    I didn't think "fuel bowls" could dump fuel into the engine...:huh:
  2. Comet4me
    Comet4me Member
    1975 Comet
    Idk. My mechanic is a Ford guy, and a friend, so I trust his opinion. Maybe I got it wrong. Something is causing a fuel leak. Maybe he said the floats I bad. Sorry I'm not sure now. I just trust that it needs to be replaced
  3. 71gold
    sounds like a botched rebuild job to me. it should have new internal parts that came in the rebuild kit.
  4. Craig Selvey
    I agree......just sounds like it needs some work.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Unless the throttle shaft bushings are worn, a proper rebuild should solve any problems, and it should not leak at all.
  6. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    If the float is sinking it will flood the engine that is most likely what is wrong, I have a 600 Holley that does the same thing it has a pin hole in the float and the float fills up with gas! When the float sinks the needle and seat stays open
    causeing the carb to flood the engine!
