simple ways to get extra Hp on a 302
Discussion in 'Technical' started by JHodges, Apr 22, 2007.
  1. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    i dont think that i can spend any more money. I spent alot of it on prom. SHEEEEESH
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Just because they are "newer" doesnt mean they are better..
    Could have smaller valves, smaller/bigger combustion area etc...
    This all affects compression ratio and getting air in/out of your motor
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    E7s are everywhere cheap because the multitude of engines they came on had them taken off because they were so... uhmmm... "good".
  4. awannabegrabber
    Wichita, Kansas
    they are better than the heads on a stock maverick.
  5. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    :deadhorse :ignore: :wow: :banghead:
  6. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Says who? You?
    E7s suck. They are not a performace head, period. Any posting work on them would work just as well on "Maverick" heads.
    BTW, there is no such thing as "Maverick" heads.
    This is the kind of deal you want on heads:
    http://www.tcstangs.com/forum/showthread.php?t=51981
    You can get GT40 heads pretty reasonable too.
  7. scooper77515
    Back on topic
    Thread has deviated from the original question to a discussion of heads...
    1) open the exhaust, 2-1/4 or 2-1/2" all the way, dualled, or dual with an X pipe. Lose the exhaust manifold and use AT LEAST a shorty header, if not full length tube headers.
    2) better heads...the better...the better....GT40s are about the best iron heads you can get cheaply and without needing to do a bunch of work on them. Just clean them off and slap them on. Of course, porting won't hurt them either.
    3) Better intake...the better...the better. Lots of arguing between the Torker289 (NOT Torker II) and an RPM Air Gap. Weind Stealth??? Of course, porting won't hurt either...
    4) advance the timing and/or recurve the timing
    5) better cam, lots of work but not too expensive, with very good benefit.
    6) An aftermarket aluminum radiator won't necessarily improve the 302, but will allow you to run cooler which might boost HP, and it will keep a higher output 302 cooler after you start tacking on the HP boosters.
    7) Nitrous:D
    8) Lose some weight. (Might be good for YOU too, if you have a little extra to lose:D ) Drop the big bumpers if you can find small replacements.
    I will think of some more later. Hopefully, this will provide some non-head fodder for everyone to improve/debate upon.
  8. NAFORD302
    NAFORD302 Member
    SILEX MO
    Easy On The Fat Jokes
  9. 20cows
    20cows Member
    West Texas
    74 Maverick
    I did that. I'm 53% of my former self (down 150 lbs).:dancing:
  10. scooper77515
    Any you have lost, I have recently found...:cry:
  11. 20cows
    20cows Member
    West Texas
    74 Maverick
    Hey, according to the formula, I picked up 15 horses!:yahoo:
  12. Andysutt
    Conway Arkansas
    1972 Comet GT
    You and me both :(
    But its summer time and i usually loose 20 or so lbs easily
  13. don graham
    now you can be known as "20 cows---15 horses":clap: .
  14. scooper77515
    That was a GREAT response:yahoo: :biglaugh: :rofl2: (y)
