simplest way to wire a Taurus fan?
Discussion in 'Technical' started by sam03rc, Jun 15, 2011.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    How can I test the fan to see how many amps are drawn? Thanks frank 30 amp I know is at advance
  2. simple man
    simple man Member
    Bunnell,Florida
  3. injectedmav
    injectedmav Member
    Georgia
    you can buy a cheap ammeter (dash mounted style) and hook the fan up with a jumper wire to see the initial spike and constant draw. It's not as accurate as the inductive type used with a DVOM, but it will get you in the ball park.
    I know many people are using fuses, but on fans, I prefer cycling circuit breakers of the calculated rating you need.
  4. bmcdaniel
    I found when I tested my Taurus fan the difference in system voltage between just the battery and having the alternator running made a difference of about 5 amps.
  5. 71gold
    Me too...:yup:
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Thanks for the link to the best source I've seen for automotive electrical things. Wish I had known about it sooner I could have saved some $$$$.
