Since I a working in the trunk...Battery mounting.
Discussion in 'Drag Racing' started by scooper77515, Feb 20, 2010.
  1. scooper77515
    I didn't know about the grounding of the cell. The rest I have covered.
  2. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    when you say sealed trunk ,do you mean from the passenger compartment or from the rest of the world?
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    from the passenger compartment . . . the rest of the world will be safe I'm sure
  4. don graham
    Let me elaborate on the grounding. Rules say that non metallic fuel cells must be grounded to frame.:)
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I'm confused :hmmm: [Some will say that's nothing new, but I digress]. How can you ground a non-metallic fuel cell, that can't conduct electricity, because it's non-metallic?
  6. PaulS
    It is grounded with a wire to prevent static dischare (called a spark) that wmight be a fire hazard.
  7. don graham
    I grounded mine to the ring going around the fill cap. There's about 10 small bolts going through the rings holding the cap.:)
  8. olerodder
    olerodder Member
    NorCal
    Here is a picture of the grounded "plastic" fuel cell. There is a wire from the metal ring on top of the cell, to the roll cage.............which is mounted to the body...................etc.
    This tech has always been inforce..........................at least for the past 20+ years.
    As for a vent, I have a return line from the pump which has been good enough for Tech. Also see the external electrical "cut off" switch and the firewall between the trunk and passanger compartment is metal.
    We will see if this will pass NHRA tech in about 3 weeks.
    IMHO
  9. scooper77515
    Duh!:slap:
    Aluminum tank, held to the car with steel straps and braces...I don't think it can be grounded any better than that!!!:biglaugh:
    I guess I have THAT covered, too!
  10. ford84stepside
    Berry Alabama
    I gotcha! You are grounding the metal parts on the non-metallic cell. I fully understand the need for no static discharge of electricity, don't want a bomb in the trunk.
  11. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    i was thinking about putting a fuel cell in my trunk on my 73.. what is the best size of cell to use ??
  12. don graham
    If you are using it on the street, I'd keep the stock gas tank. You may want to use the trunk space you'll lose. If you are building a race car I use a 5 gallon cell.:):)
  13. 71gold
    plastic will build a static charge...
    like the seat covers in your truck, they are... non-metallic...but when you slide out and touch the door, you get a shock...
    slide your feet on...non-metallic...carpet, same thing happens...:yup:
    they suggest not putting gas cans in the back of a truck that has a plastic bedliner, it will build static electricity and spark when you touch the can...:shocked:
  14. 71gold
    ...another good example...
    remember the old...clear plastic seat covers...they required a grounding strap that drug the ground under the car...without it, when you slid across the seat, your hair would stand up on end and anything you touched would cause sparks to fly.
    ...:drive:...
  15. scooper77515
    Another old thread...
    I use a grounding strap on all my daily drive vehicles dragging on the ground to reduce that shock.
