Sits way too high...
Discussion in 'General Maverick/Comet' started by William623, Nov 17, 2015.
  1. mojo
    Looks much better! That's about the way my car sits, not going to change anything, like the way it rides.
  2. William623
    Orlando
    1973 ford maverick grabber
    You were right, I thought as much also but I didn't want to risk taking too much out and end up regretting it. It'll work for now so I'm much happier. I'll be glad to not have to do this job again for awhile... Thanks mojo! I drove it a bit today, it handles so much better!
  3. Craig Selvey
    Looks much better
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Man, I'm worried that I didn't remove enough coil now.
  5. William623
    Orlando
    I hope not, that job is such a pita...but you don't know until you try.
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    My car was a big bumper 74, originally a 250 auto, and the factory springs had a spring rate of 225/inch and 1328 lbs. which seems softer than all the replacement stuff on the moog chart. These #s were taken off the factory tag. someone cut them, but I do not know how many coils were cut. If the car sits too low, they will get replaced.
  7. Armrastler
    Armrastler Member
    Monterey,Ca
    73 comet
    Factory v8 Springs with 1 .5 coils cut
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I would have stopped at 1 coil.
    Usually, 3/4 to 1 full coil does the trick, unless you have some extra stiff springs.
  9. Armrastler
    Armrastler Member
    Monterey,Ca
    73 comet
    That was with iron heads/intake, this is how it sits with aluminum heads/intake. Shaved some weight of and gained a little height back
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Wow, it sits pretty much perfect now. :thumbs2:
