Slave Cylinder
Discussion in 'Technical' started by TommyGun1928, Apr 12, 2021.
  1. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    Thus the crux of the issue. They aren't expensive by a long shot and easily available still.
  2. Krazy Comet
    Dismal Swamp
    While I highly reccomend replacing older rubber brake hoses, the ones for '70 are apparently unobtainium(and AFAIK have not for several years). Not on Rockauto, or ebay, not even Rear Counter has a source. Having them made at hydraulic hose shop is likely only option for original.
    https://www.rearcounter.com/results.php?s=D0DZ-2078-E (and F, R&L are different)
    As I stated prior, hoses for '71 are avail but at minimum require replacement of wheel cylinders as well. Those parts are same as used on '67-'71 Fairlane/Torino. R&L hoses same.
  3. dyent
    dyent Member
    vancouver bc
    mojo likes this.
  4. TommyGun1928
    TommyGun1928 Member
    Prescock Az.
    1971 Maverick Grabber
    This will be the first thing I do really didn't want to replace the slave, thanks for the help.
  5. TommyGun1928
    TommyGun1928 Member
    Prescock Az.
    I actually removed the bleeder valve completely and no fluid came out under pressure. Sounds more and more the soft line has collapsed, thanks guys you have a lot of info.
  6. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    The brake hoses wear from the inside out. the outside can look good but the inside where worn will be thin and a hole will then cause the fluid to get between them and that brake will lock up and you can't bleed them. i don't know how many miles are on the hoses but if the are original hoses. they may be worn on the inside. I all ways replace brake hoses every other time I replace the brake shoes or disc's.
  7. TommyGun1928
    TommyGun1928 Member
    Prescock Az.
    The hoses are original to the vehicle and most likely the problem, I'm impressed with all the help I'm getting here, much thanks to you guys.
  8. TommyGun1928
    TommyGun1928 Member
    Prescock Az.
