slicks/tires question
Discussion in 'Drag Racing' started by stmanser, Dec 2, 2005.
  1. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    I disagree, I don't think you'll ever get the same 60' out of a drag radial as opposed to the ET Street, sidewalls are too unforgiving.
  2. CometGT1974
    Western NC
    74 Comet GT
    I've run et drags and et streets with success, the et street seems to have a slightly stiffer sidewall as compared to the et drag. My best 60' of a 1.38 was on a set of worn out 28x12.5" et streets (actually measure 28x10"). The ET streets are the only tire for street legal drag racing, IMO. I"ve also run several different types of Hoosier but they just don't seem to perform like the MT's, IMO.
  3. RegL404
    RegL404 Member
    At that time I had 4.11, but am currently running 3.55. That was a personal best in good air with no weight in the car. I normally run the car in "bracket" mode with between 100 and 200 pounds of weight in the trunk.
  4. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    John Ford said..."normal burnouts".... :rofl2: :biglaugh: :rofl2: :rofl:
  5. Blown 5.0
    MS.
    1974 Maverick
    That is the reason for the 60 foot improvment is the stiff sidewall, No wasted enegry wrapping up the sidewall. I have pulled 1.5 g"s with the radials where with wrinklewalls 1"2s
  6. Maverick Man
    California
    ran BFG Drags Raidals, M&H's, and M/T's
    Hands Down M/T wins! though the M&Hs weren't bad.
  7. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    I've got the smallest BFG Drag Radials, 235/60/15 with 3.40 gears and mini-spool. Only raced twice so far but my best 60' was 1.70, best 1/8th mile time of 7.42 and best speed of 116mph in 1/4. Car seems to stick pretty good.
  8. CometGT1974
    Western NC
    74 Comet GT
    I don't doubt it, a stiffer sidewall can/will improve 60' times if the car isn't overpowering the tire. You're also right in saying that the drag radial tires are great street/strip tires, I don't doubt that either. However, any tire that is a street/strip compromise will not be the "BEST" at the strip, an et street will take you farther and the et drag will take you even farther.
  9. Blown 5.0
    MS.
    1974 Maverick
    It dont matter if you have 18 inch wide slicks if your car is overpowering them then they wont give good results either. Im just saying that if your suspension is set up rite for your car, the radials will give a better 60 foot and et. You can mask a bad suspension set up with slicks. The clocks and computers dont lie they have no reason too.
  10. CometGT1974
    Western NC
    74 Comet GT
    OK, now if we can just convince the Outlaw 10.5 guys of what you're saying, they will break records and be going even faster......:rofl2: :coco:
  11. stmanser
    Davenport, Iowa
    i have 3.45 gears... and no spool...
    what is the difference between a trak-lock, posi-track, mini spool.
    and what kind of setup are you running?
    with 116 in the 1/4, thats about where i want to be..
  12. Erick-Mav
    Oceanside, CA
    A mini spool locks up the rear end for equal power to both wheels. It works good for drag racing but is bad (unsafe) for the street. Mini spools are cheap though, like $20 on ebay.
    My suspension is stock except subframe connectors and a 10pt cage. I think my suspension is getting worse though cause my 60' times are getting slower, but my mph is getting better. Time for slicks.
    To go 116mph you'll need about 365HP at the wheels with the right tires, gears, etc.
  13. Comet155
    Comet155 Member
    Track-Lock: Ford name for limited slip differential (using friction discs/clutches)
    Posi-Track: GM name for the same type of unit
    Mini spool: Similar to a full spool only the mini just replaces the spider gears and locks the axles together for constant 50/50 distribution, just like a full spool.
    Lock-Right: Locking unit that acts like a spool in a straight line, but unlocks for corners. Replaces spiders also. Kinda like a Detroit unit but ratchets on teeth (with locking pin) rather than just "bolting" and "unbolting".
    At least that's my guess. Others can chime in with their .02
    As a side note, my Lock-Right has been going strong for 11 years now without a hitch.
  14. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Then you need to try them. Seriously. They're that good.
  15. Blown 5.0
    MS.
    1974 Maverick
    __________________
    Electronic distribtors took the place of points, Fuel injection took the place of carbs, Radial tires took the place of bias, radial slicks will take the place of bias. Even as we argue the top fuel teams are testing Radial tires. The point ive been trying to make is, If and i said if Your or my car is set up correct RADIAL TIRES will be faster.
