Slight vibration
Discussion in 'General Maverick/Comet' started by wolfheads, May 16, 2020.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I notice a slight vibration in my 302 @ 50-55 mph. I noticed the crank pulley is slightly out of round when at idle. Not warped but the belt is moving slightly up and down. maybe 1/4 inch or less. Could this be the pulley is off center or the harmonic balancer ? It's had this issue since day one.
  2. 71gold
    MPH shouldn't play a part in the vibration. if it's motor, RPM should show where it comes in and out.
    JMO
    Hotrock likes this.
  3. ike72com
    ike72com Member
    Charleston SC
    What i suggest if you,re concern with pulley is to take off and inspect. While you,re there take a peak at balancer.
    As for the vibration you,ll have to do some process of elimination.
    Tire balance, driveshaft, is tranny to engine bolt all tighten?
    Another suggestion you can try is take note at what rpm you're at where vibs occurs. Now rev motor at rpm in park and/or neural. Anything unusual?
    You gotta figure out if in engine or from engine back.
    Hope you understand what i,m suggesting.
    wolfheads likes this.
  4. Krazy Comet
    Easy, run it up to 60 mph or so and put trans in neutral. If vibration is still there at 50-55, ain't the engine.
    Hotrock, 71gold and RMiller like this.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Where do you feel it, in the seat, steering wheel and can you pin point the direction it's coming from? The speed you say it happens is in the sweet spot for tire imbalance so it might be the best place to start. As far as the pulley, it may have taken a hit at some point and narrowed the groove. I had that happen on a Pontiac I used to have, engine was swinging on the hoist and bumped a stationary object with it.
  6. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Have you replaced your universal joints in your driveshaft lately? Could be one of them is bad. - Matt
    jasonwthompson likes this.
  7. mojo
    Driveshaft could be out of balance or bent? I had the problem of bent and out balance when I got my car; at around 60 mph got vibes. I would also check harmonic balancer for rubber isolation material integrity.
  8. wolfheads
    wolfheads MadMav
    Florida
    Yeah, I've done that. When in neutral at 60 mph and engine idles down, The vibration is not noticeable.
  9. 71gold
    balancer coming apart...weight came off flexplate or loose bolts...JMO
    mojo likes this.
  10. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Glad you found it before I got worse. I had a slipping balancer ring knock the crank pulley off at 70mph once on one of my Cougars. It didn't really warn me with a vibration beforehand, but it sure got my attention when the pulley started to ricochet all over the front of the engine compartment.
  11. wolfheads
    wolfheads MadMav
    Florida
    I noticed the harmonic balancer is spinning true but the crank pulley is not. Like it's off center a bit.
