Sluggish repsonse and stalling
Discussion in 'Technical' started by borjawil, Dec 25, 2011.
  1. borjawil
    borjawil Member
    lansing mi
    1972 Ford Maverick Sprint
    i6 200 engine. headers just installed. I can give it gas and itll drive but if i give it even half throttle to quicky itll die. Any ideas on what to check or settings for my 1 bbl carb?
  2. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    Choke stuck?
  3. Craig Selvey
    First....you need to make sure you have your vacuum lines hooked up correctly, like you have been asking in the other thread. We need to fix your first problem before we move on to the next one....they are probably related.
  4. 71gold
    1 too many...headers...equals exhaust too free flowing...:yup: remove 1 of the headers and try it again...
    ...:D...
  5. Craig Selvey
    Now Frank.....keep in mind he might REALLY follow your advice. :D
  6. 71gold
    :hmmm:...why do they make a header for a 200 anyway...:huh:
  7. borjawil
    borjawil Member
    lansing mi
    funny. I think i have the vacuum lines connected correctly. will post in other thread.
  8. 71gold
    ...:Handshake...I can be at times...:rofl2:
  9. mojo
    Is the carb a DIY rebuild? Sounds like ur accelrator pump may not be workin properly. Was the car running ok b4 the header install?
  10. borjawil
    borjawil Member
    lansing mi
    Yes I rebuilt the carb had it running good with the stock exhaust. It had a leak so i removed it breaking off some manifold bolts. car sat without the head on it for a little bit until i could them machined out. So carb could need another cleaning. It might also need another gasket between the intake and it as well. Going to pick that up later today. So that might be the cause.
  11. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    9 times out of 10 its the carburetor and vacuum lines.
    Make sure the body screws on the carburetor havent loosened up since the rebuild and make sure the carb base is truly flat to the head so excess air isnt being pulled through.
    Check the choke plate like also suggested.
  12. mojo
    I wud'nt think the carb wud not need another rebuild seeing as tho u just installed a new kit. Im still thinkin accel pump. If u look in the mouth of the carb and pull the carb linkage wide open u shud see a gud strong stream of gas go in the engine. If u don't; my guess is thats ur problem or at least a big part of it.
  13. borjawil
    borjawil Member
    lansing mi
    ok well either way I am replacing the carb with one that most likely came with the engine. The metal line that went to the choke on this carb isnt on it since that part of the carb body where the threads are broke off. Ill be posting a new thread on the new cabr and getting it hooked up. thanks.
