Small Block Ford Head Casting Numbers
Discussion in 'Parts Interchange' started by CaptainComet, Apr 23, 2018.
  1. CaptainComet
    I found a reference list online for all Ford OHV cylinder head castings. I edited out all the numbers that weren't Ford small blocks and that is the list below. What you see below is basic specs and the original years they were used.
    The numbers are coded to show the year. The first character is the decade ..
    C = 1960s
    D = 1970s
    E = 1980s
    F = 1990s
    The second character is the year in that decade.
    If you would like to see the entire list for other Ford engine families, it is at
    http://www.streetmusclemag.com/tech-stories/engine/reference-ford-ohv-cylinder-head-casting-numbers/
    Enjoy!
    C2OE – 1962, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C2OE-A – 1962, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C2OE-B – 1962, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C2OE-C – 1962, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C2OE-D – 1962-1963, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C2OE-E – 1962-1963, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C2OE-F – 1962-1963, 260, Windsor small-block, 1.59/1.39 valves, 49.2cc chambers
    C3AE – 1963, 260, Windsor small-block, 1.67/145 valves, 49.2cc chambers
    C3AE-A – 1963-1965, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chambers
    C3AE-F – 1963-1964, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chambers
    C3OE – 1963, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers. Hi-Po
    C3OE-A – 1963, 221, Windsor small-block, 1.59/1.39 valves, 45cc chambers
    C3OE-B – 1963, 260, Windsor small-block, 1.59/1.39 valves, 49.2cc chambers
    C3OE-E – 1963, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chambers, Hi-Po
    C3OE-F – 1963, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chambers, Hi-Po
    C4AE – 1964-1965, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C4AE-C – 1964-1965, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C4OE – 1964, 260, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C4OE-A – 1964, 260, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C4OE-B – 1964, 260, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C4OE-B – 1964-1965, 289, Windsor small-block, 1.78/1.45 valves, 54.5cc chambers, Hi-Po
    C5AE – 1965-1966, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C5AE-686 – 1965-1968, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C5AE-A – 1965, 289, Windsor small-block, 1.78/1.45 valves, 49.2cc chambers, Hi-Po
    C5AE-B – 1965, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
    C5AE-E – 1965, 289, Windsor small-block, 1.78/1.45 valves, 54.5cc chambers, Hi-Po
    C5DE-B – 1965-1967, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chambers
    C5OE-A – 1965-1967, 289, Windsor small-block, 1.78/1.45 valves, 54.5cc chambers, Hi-Po
    C50E-E – 1965289, Windsor small-block, 1.78/1.45 valves, 54.5cc chambers, Hi-Po
    C6AE – 1966-1968, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chambers
    C6AE-A – 1966, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
    C6AE-G – 1966, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
    C6OE – 1966, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
    C6OE-C – 1966, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber, Smog
    C6OE-E – 1966, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber, Smog
    C6OE-M – 1966, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber
    C7OE – 1967, 289, Windsor small-block, 1.78/1.45 valves, 54.5cc chamber, Hi-Po, Shelby
    C7OE-A – 1967, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber, Smog
    C7OE-B – 1967, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber, Smog
    C7OE-C – 1967, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber
    C7OE-C – 1967-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber
    C7OE-D – 1967, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
    C7OE-G – 1967-1968, 302, Windsor small-block, 1.67/1.45 valves, 63cc chamber
    C7OE-G – 1967-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber
    C7OZ-A – 1967, 289, Windsor small-block, 1.67/1.45 valves, 49.2cc chamber
    C7OZ-B – 1967, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber, Smog
    C7ZE – 1967, 289, Windsor small-block, 1.78/1.45 valves, 54.9cc chamber, Hi-Po
    C7ZE-A – 1967, 289, Windsor small-block, 1.67/1.45 valves, 54.5cc chamber, Hi-Po Smog
    C8AE-J – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber
    C8DE-F – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber
    C8OE – 1968, 289, Windsor small-block, 1.67/1.45 valves, 63cc chamber
    C8OE-D – 1968, 289, Windsor small-block, 1.67/1.45 valves, 63cc chamber
    C8OE-F – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 53.5cc chamber
    C8OE-J – 1968, 302, Windsor small-block, 1.67/1.45 valves, 63cc chamber
    C8OE-J – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber
    C8OE-K – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber, Smog
    C8OE-L – 1968, 289, Windsor small-block, 1.67/1.45 valves, 63cc chamber, Smog
    C8OE-L – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber, Smog
    C8OE-M – 1968, 289, Windsor small-block, 1.67/1.45 valves, 63cc chamber, Smog
    C8OE-M – 1968-1970, 302, Windsor small-block, 1.78/1.45 valves, 63cc chamber, Smog
    C8TE – 1968-1970, 302 , Windsor small-block, 1.78/1.45 valves, 63cc chamber
    C8ZE-B – 1968, 289, Windsor small-block, 1.78/1.45 valves, 54.5cc chamber, Hi-Po, Service
    C8ZE-B – 1968, 289, Windsor small-block, 1.78/1.45 valves, 54.9cc chamber, Hi-Po, Service
    C9OE-B – 1969-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    C9OE-D – 1969-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    C9OE-E – 1969-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    C9TE-C – 1960-1970, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    C9ZE-A – 1969, 302, Cleveland/Windsor small-block hybrid, 2.23/1.71 valves, 63cc chamber, Boss
    D0AE-E – 1970-1974, 351, Cleveland small-block, 2.04/1.66 valves, 73.2cc chambers
    D0AE-G – 1970-1971, 351, Cleveland small-block, 2.19/1.71 valves, 62.8cc chambers
    D0AE-H – 1970-1971, 351, Cleveland small-block, 2.19/1.71 valves, 62.8cc chambers
    D0AE-J – 1970-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D0AE-M – 1970-1971, 351, Cleveland small-block, 2.19/1.71 valves, 62.8cc chambers
    D0AE-N – 1970-1971, 351, Cleveland small-block, 2.19/1.71 valves, 62.8cc chambers
    D0AE-R – 1970-1971, 351, Cleveland small-block, 2.19/1.71 valves, 62.8cc chambers
    D0AZ-A – 1970-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D0AZ-B – 1970-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D0AZ-D – 1970-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D0OE-B – 1970, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D0OE-C – 1970-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D0OE-G – 1970-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D0OZ-C – 1970-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D0ZE-A – 1970, 302, Cleveland/Windsor small-block hybrid, 2.19/1.71 valves, 58cc chamber, Boss
    D0ZE-B – 1970, 302, Cleveland/Windsor small-block hybrid, 2.19/1.71 valves, 58cc chamber, Boss
    D1AE – 1971-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D1AE-A – 1971-1973, 400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D1AE-A1A – 1971, 400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D1AE-A1B – 1971, 400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D1AE-A1C – 1971-1973, 400, Cleveland small-block, 2.04/1.66 valves, 75.6cc chambers
    D1AE-A2C – 1971-1973, 400, Cleveland small-block, 2.04/1.66 valves, 75.6cc chambers
    D1AE-AA – 1971-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D1AE-AB – 1971-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D1AE-AC – 1971-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D1AE-CB – 1971-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D1AE-GA – 1971-1974, 351, Cleveland small-block, 2.19/1.71 valves, 58cc chambers
    D1OE – 1971-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D1OE-BA – 1971-1974, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D1TZ-A – 1971-1974, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D1TZ-BB – 1971-1974, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D1ZE-A – 1971, 302, Cleveland/Windsor small-block hybrid, 2.19/1.71 valves, 58cc chamber, Boss, Service
    D1ZE-B – 1971, 351, Cleveland small-block, 2.19/1.71 valves, 66cc chambers, Boss
    D1ZE-CB – 1971-1974 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D1ZE-DA – 1971, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers, Cobra Jet
    D1ZE-GA – 1971-1973, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers, Cobra Jet
    D2AE – 1972-1974, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D2OE-BA – 1972-1974, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D2OE-DA – 1972-1974, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D2ZE-A – 1973, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers, High Output
    D2ZE-B – 1973, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers, High Output
    D3AE – 1973-1975, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D3AE-G2B – 1973-1974, 400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D3VE-AA – 1973-1974, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D3ZE-AA – 1973-1974, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers, Cobra Jet
    D4AE – 1974, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers
    D4AE-AA – 1974-1975, 351, Cleveland small-block, 2.04/1.66 valves, 76.2cc chambers
    D4AE-AA – 1974, 400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D4AE-B2A – 1974, 400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D4AE-BA – 1974, 351, Cleveland small-block, 2.19/1.71 valves, 75.4cc chambers
    D4DE-AA – 1974-1979, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D4DE-AB – 1974-1979, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D4DE-BA – 1974-1979, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D4DE-BB – 1974-1979, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D4VE – 1974, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5AE-A – 1975-1978, 351M/400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D5AE-A1A – 1975-1978, 351M/400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D5AE-A2A – 1975-1978, 351M/400, Cleveland small-block, 2.04/1.66 valves, 74.5cc chambers
    D5AE-A3A – 1975-1978, 351M/400, Cleveland small-block, 2.04/1.66 valves, 74.5cc chambers
    D5AE-AA – 1975-1978, 351M/400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D5AE-BA – 1975-1978, 351M/400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D5AE-CA – 1975-1976, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5AE-DA – 1975-1976, 351, Windsor small-block, 2.04/1.66 valves, 75.4cc chamber
    D5AZ – 1975-1979, 351M/400, Cleveland small-block, 2.04/1.66 valves, 78.4cc chambers
    D5DE-AE – 1975-1976, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5OE-A – 1975-1978, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5OE-A3A – 1975-1979, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5OE-A3B – 1975-1976, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5OE-A4B – 1975-1979, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5OE-AB – 1975-1977, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5OE-GA – 1975-1976, 302, Windsor small-block, 1.78/1.45 valves, 58.2cc chamber
    D5TE-DA – 1975-1977, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D5TE-EA – 1975-1977, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D5TE-EB – 1975-1977, 351, Windsor small-block, 1.84/1.54 valves, 60.4cc chamber
    D7OE – 1977-1978, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE – 1977-1981, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-A – 1977-1978, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-A – 1977-1981, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-A4B – 1977-1979, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-DA – 1977-1979, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-DC – 1977-1978, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-DC – 1977-1979, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7OE-GB – 1977-1979, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D7TE-AB – 1977-1978, 400, Cleveland small-block, 1.78/1.45 valves, 69cc chambers
    D8OE-A – 1978-1979, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D8OE-AB – 1978, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D8OE-AB – 1978-1984, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D8OE-CB – 1978, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D8OE-DA – 1978-1979, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D8TE-AB – 1978-1979, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D8TE-BB – 1978, 351, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    D9AE-AA – 1979-1984, 351M/400, Cleveland small-block, 1.78/1.45 valves, 69cc chambers
    D9OE-A – 1979-1984, 302, Windsor small-block, 1.78/1.45 valves, 69cc chamber
    E0SE-AB – 1980, 255, Windsor small-block
    E5AE-AB – 1985-1987, 302, Windsor small-block, 1.78/1.45 valves, 66cc chamber, GT
    E5AE-CA – 1985-1987, 302, Windsor small-block, 1.78/1.45 valves, 66cc chamber, GT
    E5TE-AB – 1985-1987, 302, Windsor small-block, 1.78/1.45 valves, 66cc chamber
    E5TZ – 1985-1987, 302, Windsor small-block, 1.78/1.45 valves, 66cc chamber, GT
    E6SE-AA – 1986-1991, 302, Windsor small-block
    E7SE – 1987, 302, Windsor small-block
    E7TE-PA – 1987-1995, 302, Windsor small-block, 1.78/1.45 valves, 66cc chamber, GT
    F1ZE-AA – 1991-1996, 302, Windsor small-block, GT40
    F1ZE-AA – 1991-1995, 351, Windsor small-block
    F2PE – 1993-1995, 302, Windsor small-block, GT40
    F3ZE – 1993-1995, 302, Windsor small-block, GT40
    F4ZE– 1993-1995, 302, Windsor small-block, GT40
    F77E-AA – 1997-2001, 302, Windsor small-block, GT40P
    Russell, mercgt73 and Hotrock like this.
  2. Hotrock
    Munroe Falls, Ohio
    Great work Captain! I cut and pasted your information to a Word document for safe keeping.
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    wow.. lots of info there confusing my old brain! Never seen a post-'66 289 or 302 SBF head with 1.67" intake valves. Must have been those Cali smoggers or some weird combo's I've never run across. Learn something new every day.
  4. baddad457
    I see a few mistakes in there too. Like the C8ZE head, that was used on the 68 302 4 bbl engines. And the dates on the E7TE heads. These were used on all the 302's and 351W's in the pickups and vans and up into the 97 model year in the F250's with a 351W engine. Those with the 4th digit "Z" is a part number, not an engineering number found on the head. Pretty sure the common C6OE 289 heads all had 1.78 intakes too.
  5. CaptainComet
    I take no responsibility for the accuracy of the list. I just Copy and Pasted .... ;););)
    It looked good for the heads I am personally familiar with.
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    You know what they say, Jeff.. no good deed goes unpunished. :slap:
    JK.. gotta start somewhere. :tiphat:
  7. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    I agree with you on the C6 head castings I have two sets and both Came with a 1.78 intake and 1.45 exhaust. the numbers must be California heads!
