Small mods on a 1970 meverick 250cid ,help!
Discussion in 'Technical' started by miguel, Jan 5, 2013.
  1. captainmack
    captainmack Quad Door
    Red to coil +.., and black to coil -.
    yes..
  2. miguel
    miguel Member
    GARDENA ,CALIFORNIA
    1970 maverick
    well my car started running really bad when i did that so i just put the points back in . i put the car in drive and it started jerking bad .so now im confused .any help on this problem? thank you
  3. Joe Dirt
    wrong petronix kit? maybe a 8 cyl magnet
    im not a fan of them personally
  4. captainmack
    I would not have given up so easily, the Pertronix do work. Do you still have the instruction??
    http://www.pertronix.com/support/manuals/pdf/ignitor12vneg.pdf
    Something got installed wrong. did the magnet thingy (reluctor) go on the rotor correctly? did you open the gap on the plugs from stock .035" +to .045" ??
  5. captainmack
    Good "point", Dirt... lol check the 8 or 6 kit thing.
    I've installed these on boats with twin 350 engines etc... cars, countless, for 20 years.. Never failed some in service that long!
    Whats not to like???
    Oh... they dont say MSD :)
  6. rthomas771
    I'm not either. I tried both in my Maverick. The Duraspark gives better performance and better MPG...night and day difference
  7. Joe Dirt
    i had one catch on fire and burn so ill never buy another
  8. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    make sure to bypass the resistor wire. I did the same thing and bought a relay kit and worked fine.
  9. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    Buy the Ford Six performance handbook if you plan to do anything.
    First...before you do anything to the engine itself, do as others say...install the duraspark distributor. You can order this from any parts warehouse, brain box and all.
    2nd...you still want more mods to do? Find a machine shop locally and follow some of the advice on this thread
    http://fordsix.com/forum/viewtopic.php?f=1&t=68838&p=527657&hilit=head+milling+250#p527657
    you need to bring your compression ratio up, especially when head gaskets are swapped. Milling the head is need be.
    3rd...Still want more power?
    While the heads off have the machine shop custom fit a 2 barrel carb flange for your head. Info can be found in the handbook and fordsix.com
    4th...still want more go power, head over to classicinlines.com and tell them your setup and order a cam, lifters, and springs for your build. Order some headers from them while your there. :)
    Thats just a 'rough' run down for a 250. Like others have said, it'll cost money that no gm 350 or SBF would require comparatively.
    I recommend for those building a tom cat of a inline 6 to get the 200, it has better top end then the 250. The 250 is out of steam about 3,500-4,000 RPM and isn't wise to keep it up there. The more gears you have for a straight six the better. Pair a 5 speed with the 250 and can keep the RPM's low enough to get the torque to the ground 5 times fast.
    My 2 cents:jack:.
