So, how do you break in piston rings
Discussion in 'Technical' started by justin has a 74, Jul 1, 2010.
  1. bmcdaniel
    You're correct, there are chrome-faced rings and moly-faced rings, but not chrome moly.
  2. PaulS
    The chrome/moly rings are (or used to be) chrome rings with a groove (or two) that was filled with moly. This was supposed to allow the ring to seat faster like a moly ring and to last under high pressures and speeds like a chrome ring. It was not very successful because the coarse finish needed for the chrome ring usually rolled the moly out of the groove. They were not made of chrome-moly steel.
    You guys are way too young!:D
  3. baddad457
    Nope, not too young. Just never saw those rings. Only ones I've ever run across were black iron, chrome, and moly rings.
  4. PaulS
    Hastings makes the 2M 4026 rings for 2.5L turbo. This is a Plasma-Moly top ring (also known as Chrome-Moly because of the impregnated chrome in the Plasma-Moly)
    The ring material is ductile iron and in this case the plasma has both chromium and moly in it. There are others 2c4666 from Hastings for the Accura.
    http://www.hdmaddog.com/Acura-chrome-moly-piston/Honda-Acura/Piston-Rings/-p3677864.html
    Acura chrome moly piston rings B17A1 1992-93
    HST-2C4666 Brand new full set of chrome moly piston rings for the 1992-93 4-cylinder 1678cc B17A1 engine - 1.0mm 1.2mm 2.8mm configuration - 81mm (3.189 bore in standard - std. .010 .020 .030 .040 available
