So my car now has a Tremec TKO
Discussion in 'Transmissions' started by markso125, Aug 14, 2011.
  1. Hotrock
    Munroe Falls, Ohio
    Well done! :thumbs2:
  2. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I ran across one on Youtube recently which had a Nissan 240sx clutch pedal, master, and slave cylinder.
  3. mavmo
    mavmo Member
    Vancouver wa.
    73 maverick
  4. mavmo
    mavmo Member
    Vancouver wa.
    73 maverick
    Hello, what did you end up using for a driveline? Getting ready to put a tkx in my 73, thanks.
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    The Tremec transmissions for Fords use the same 28 spline slip yoke across the board. C4, AOD, T5 and the Ford Tremec 3550 all use the same thing, so i just used the stock C4 driveshaft i had in it. No cutting or anything involved. Dimensionwise the transmissions are similar. The C4 AOD swap is pretty common and alot of people dont have to change their driveshafts, the dimensions for those are
    Overall Length (bellhousing to tailshaft housing end, flat-to-flat):
    AOD - 30 3/4 inch
    C4 - 30 1/4 inch
    TKO - 31 inch
    TKX - 31 inch
    T5 - 31 3/4 inch
    Now just so you are aware the 28 spline output shaft is only applicable to the 3550's. Both the TKO and TKX transmissions use a 31 spline output shaft so you will need to change the slip yoke to match the transmission, you should be able to use the rest of the driveshaft or have one custom made.
    mojo likes this.
  6. mavmo
    mavmo Member
    Vancouver wa.
    73 maverick
    Thankyou for the info and you appear to be the only one on the internet that has done that in a mav! Which helps me a lot as my tkx is pretty similar to your tko.
  7. Shorty
    Shorty Member
    Lafayette, In
    I replaced a top loader 4-speed from a '70 Boss 302 with a new Tremec TKO-600 in my Maverick. As Markso125 notes it was a direct swap needing a new yoke on my existing driveshaft and a new clutch to match the TKO input shaft splines. It is an awesome transmission!
    Bruce
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Not sure how I missed this thread, did you do much modification to the floor? I ended up raising the tunnel about 1 1/2 inches. I also made my own trans mount loosely based on the one Holley sells for an early Mustang.
  9. Shorty
    Shorty Member
    Lafayette, In
    Rick, on the factory floor I really opened it up more for the 4-speed installation because of the Hurst Super shifter linkage which is rods welded insides tubes. With the Tremec, as you stated, I had to open up the top of the tunnel. Later I had the car back-halved and new floor was installed from the trunk all the way to the toeboards. The 1st oicture shows my attempt to repair what I had done to the floor to clear the shift linkage while opening up the top for transmission clearance. The 2nd picture shows the new floor as I was putting in Fat Mat.
    mojo and RMiller like this.
  10. mavmo
    mavmo Member
    Vancouver wa.
    73 maverick
    That tunnel work looks good!
  11. Shorty
    Shorty Member
    Lafayette, In
    I think they did a great job on the car and I really enjoy driving it.
    Bruce
  12. markso125
    markso125 Member
    Lewiston Ut
    Thanks i cant believe i did this over 10 years ago, i still love the setup in the car... And sad to say this is one of the things that there isnt much information on im glad i could help someone.
  13. RMiller
    Kennewick, WA
    That looks great! When I started cutting into mine I cut out ahead of where the shifter would be. Turned out that wasn't enough so I cut back to the rear of the shifter. It's not bad but will look way better when the carpet goes in!
    mojo, Shorty and markso125 like this.
  14. Shorty
    Shorty Member
    Lafayette, In
    Rick, your's looks so much better than the job I did on mine!
    Bruce
    RMiller likes this.
  15. mojo
    What’s the fitting on upper passenger side of the hump. Nice work on the hump mod.
