Soft brake pedal issues
Discussion in 'Technical' started by 7D2 Grabber, Jan 6, 2014.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Master is from a 74 Mav, manual disc (1in bore). Many have used the master with good results. There is no facyory residual valve in this master. The explorer rear has both bleeder screws pointing down. The cobra calipers up front have one pointing up and the other pointing down.
  2. Moneymaker 1
    Panama City Florida
    There is the problem then, they must be at the top or pointing up to properly bleed the brakes.
  3. 7D2 Grabber
    7D2 Grabber Member
    I'll get these calipers pointing up and bled soon and post up the results. Thanks for the input.
  4. 7D2 Grabber
    7D2 Grabber Member
    Just bled the front right which had the bleeder pointing down, It had a ton of air. Did the left front which had a little as well. It's a little better but not safe. I checked the right front again and found more air. There must be an internal leak somewhere.
    After double checking the rear calipers, the bleeder points out not down. I left those alone since they were just bled recently.
  5. Paul Masson
    1971 Grabber
    Are they at the 'top' of the caliper or at the bottom? They need to be higher than the caliper pistons to bleed properly.
  6. Moneymaker 1
    Panama City Florida
    Man I hate to sound like a broken record, but I thought the very same thing about a leak, make sure the bleeders are at the top and bleed then reinstall.
  7. 7D2 Grabber
    7D2 Grabber Member
    I'll do them all again just to cross that off my list.
  8. 7D2 Grabber
    7D2 Grabber Member
    I'm thinking of buying a vacuum pump instead of using the old fashioned way.
  9. Bryant
    ok you said the front right has the bleeder pointing down?
    this is your problem.
    the bleeders have to be in the highest point on the calipers hydraulic system.
    take the caliper off. put something between the pads that is at least as thick as the rotor. turn the caliper into a position with the bleeder at the highest point. then bleed the brakes. then put the caliper back on.
  10. Bryant
    just read the earlier posts.
    you need to switch the rear calipers on the rear to get the bleeders on the top. it sounds like you have a drivers side caliper on the passenger side and need to get a passenger side caliper. if thats not possible then do as i said above.
  11. 7D2 Grabber
    7D2 Grabber Member
    I stuck a piece of wood in between the pads. The odd thing was I removed all of the air from the side that had the bleeder pointing down and moved on to the driver side. Removed the air from that side and went back to the side with the bleeder pointing down and it had air in it again. When I removed the air I submerged a hose attached to the bleeder with brake fluid so I could see the air bubbles come out.
  12. dyent
    dyent Member
    vancouver bc
    you have to bleed from the furthest caliper away from the M/C first, which is the RH rear, then LH rear, RH front and finally the LH front....good luck!
  13. 7D2 Grabber
    7D2 Grabber Member
    The rears were already bled a day or two prior. So I started with the r/f and ened with the l/f
  14. dyent
    dyent Member
    vancouver bc
    Sounds like you are making good progress!
    If you are looking at purchasing a really good bleeder kit, this is the one I use.
    http://www.summitracing.com/int/parts/mvp-0252/overview/
    probably can get cheaper, I got mine not too far from you, www.SkywayTools.com in Chico, CA. this thing works great and you don't have to keep on checking/filling M/C!
  15. Moneymaker 1
    Panama City Florida
    And I even went that route also lol, I made my own, ran a clear hose from my carb vacuum into the lid of a jar, ran another hose from the jar to the bleeder, started the car and instant vacuum pump, still had all the issues you describe, finally bled the calipers with the bleeder screws at the top and I had brakes!
    I also went through 5 MC, looked for leaks, tightened everything up, drove me crazy for over a week.:thumbs2:
