Soft brake pedal issues
Discussion in 'Technical' started by 7D2 Grabber, Jan 6, 2014.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Problem solved, you guys nailed it. Bled the rears with the bleeder pointing up and the fronts as well and now I have a good pedal. Thanks guys.
  2. Paul Masson
    1971 Grabber
    Glad to hear it worked for you! The other thing I do when bleeding brakes, is I start with the caliper farthest away from the master cylinder and work my way back to the one closest to the MC.
    Typically: RR, LR, RF, LF.
