soild motor mounts
Discussion in 'Drag Racing' started by JHodges, Dec 18, 2013.
  1. mav1970
    My engine builder, who's family have drag racing history going back to the late 50's, told me that it was OK to mount my aluminum engine plate solid to my cage but it was imperative that I keep the stock rubber transmission mount :yup:
  2. mercgt73
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No rudeness intended. 'Sorry it came across that way. :Handshake
  4. JHodges
    JHodges thumper
    Dora Alabama
    it's all good:thumbs2:
  5. Boss302maverick
    Boss302maverick Member
    New Jersey
    1971 maverick grabber
    Im not a fan of solid engine mounts, unless your car has a full cage, and is tied out front, I have had very high end engine builders explain to me that the torque on the leave of a drag car pulls on the wall of the block, witch then does all sorts of funky things to cylinder walls. when I worked at IROC and we ran the dodges, we ran solid mounts, almost everytime we wrecked a car, we broke the motor mount tabs off the block and that was with a Banjo Mathews stock car chassis, Then Richard Petty told us to use rubber mounts, and we stopped breaking blocks, and started breaking mounts and fan shrouds after a wreck. Years ago when I bought the oem type mounts for my Maverick, the LS mount came with a rivet through the whole assy, I still use those mounts and have well over 1000 passes through the 25plus years I have raced my car.
    just my opinion
    Duane
  6. Reeves1
    Reeves1 Member
    Alberta Canada
    I have a set.
    Ford # D5ZA-6038-BD
    Just had a quick look on line for them & didn't find them though.
  7. Boss302maverick
    New Jersey
    yes, that's them, seems to be from a 75 mustang with the Z designation
    Duane
  8. Reeves1
    Reeves1 Member
    Alberta Canada
  9. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Does anyone know if there is an place to purchase motor mounts that will have the rivet on the Left Side motor mount?
  10. Craig Selvey
    Motor mounts are the same for both sides. No such thing as a left or a right.
    Sorry....I do not know where to buy one with the "pin".
  11. Cruzin Illusion
    1972 Grabber
    I figured that but I was going off the statement from Duane's post.
    Thanks for the information Craig. You are always a help. I also saw that someone post in my research that they bought a set from O' Reilly's and they had the pin/rivet in them. I will check there tomorrow and see.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Do they have CarQuest where you live?
  13. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    That's good to know, for Ford.
    But it is not necessarily true with Chevrolet and I wouldn't have believed it had I not experienced it while trying to drop a 396 in my '69 Chevelle SS back in '86...
  14. Cruzin Illusion
    1972 Grabber
    Yes. I will ckeck with them as well.
  15. rthomas771
    Early Falcons have a left and right mount. I pinned my own mounts on my Falcon. The same could be done the same with Maverick mounts.
    [​IMG] [​IMG]
