Something i noticed
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Jun 26, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    So over the last few weeks ive been messing with my timing as some of you know but have noticed that the timing seems to go from perfect to slightly off 5 degrees or more after i drive it. Yet sometimes nothing changes at all. Ive been confused.
    I checked for vacuum leaks and everything else and came up empty until just now.
    Ive been meaning to swap over to the smaller dist cap and rotor but havent yet because of work and lack of time, and have kept using the oversized adapter cap and big button because of the wrong plug wires recieved weeks ago.
    Today i wondered if the lose feeling oversized cap was moving enough to cause timing changes. With the engine running, i barely twisted the cap just enough to move the back and forth play it had and the engine died. Iit wouldnt crank again until i took it apart and reset the rotor button. Apparently this small movement caused just enough slop to mess with my timing. I put it back together and tapped it down.... Cranked it and reset timing. It runs perfect now when the play is limited. Tomorrow ill switch over to the small cap and button as intended. Ive been racking my brain thinking i had worse problems i couldnt find.
    Anyone else ever have this problem or knew about this?
    Pic included of the bigger cap.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I have no idea, but that engine sure looks good .
    CaptainComet and satchelmcqueen like this.
  3. satchelmcqueen
    north georgia
    Thanks. The valve covers is what does it for me.
  4. Acornridgeman
    Wisconsin
    I think you have nailed it with the cap fit issues.
    satchelmcqueen likes this.
  5. yellow75
    Tillamook Oregon
    Beware those valve covers scratch easily, even the plastic wire looms will scratch them . And yes it looks great glad it has all came together and you have learned a lot, well maybe we all learned something
  6. Krazy Comet
    In the real world, the cap has zero to do with timing, to alter timing the dist housing has to move. Moving the cap will effect rotor indexing, meaning the rotor may be misaligned to point the spark has to jump from rotor to dist terminal. In a severe case, spark may jump to two adjacent terminals.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Just to be safe, send my your carb and you can get another.
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    Nice motor! Make sure your lower hose doesnt collapse when you rev up. I had an issue with one shaped like yours.
  9. William623
    Orlando
    1973 ford maverick grabber
    They sell a spring that you can put in it to stop that. Just look for a mustang one.
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    Parts stores around me didnt stock the molded hose with a spring....so I used a ribbed hose. I never thought about trying to buy just a spring.
  11. satchelmcqueen
    north georgia
    Yep thats it. I drove it 180 miles today and its the biggest test yet and it ran perfect the entire way. I checked timing eevery 50 miles and it was dead on. The small cap is solid and doesnt move at all. No slop.
    Acornridgeman likes this.
  12. satchelmcqueen
    north georgia
    Ill def check that tomorrow.
  13. bmcdaniel
    I've made my own "spring" by winding up a piece of metal coat hanger and stuffing it in there. Just make sure it's tight so it doesn't work it's way up into the water pump.
  14. satchelmcqueen
    north georgia
    So if it starts again does that mean the distributor may be bad?
  15. Krazy Comet
    I doubt you have a dist problem, to alter timing the gear would have to slip.
    I have seen badly worn dist cause erratic timing but OK at idle, jumped around at higher RPM.
