Sorry........spring removal again!!
Discussion in 'Technical' started by MaverickRunner, Mar 1, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Probably not the safest way .... and that won't work if you are working on just the shell since there won't be enough weight to compress the spring ... BOIIINNNNGGGG ... :)
  2. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    I got ya, I know when a car is all together its easy to remove one and with all the tension off the spring it just falls out, but good advise from everyone.
  3. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    Thanks Guys...I see ebay has some for sale, loan a tool hasnt made it to Wyoming!!
    Todd
  4. Craig Selvey
    Won't work on a stock spring. The upper a-arm bottoms out on the frame before the spring loses any of it's tension.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Correct!
    I had the same thoughts before I did it the "frahler" way. :yup:
    :tsk: no torches were used during the harming of my springs :D
  6. don graham
    anybody tried that disc they sell on ebay. it seems that you remove the upper claws and put the disc on, insert it in to the spring and tighten it up. :huh:
  7. Acornridgeman
    Wisconsin
    Check this old thread - in post #21 of that thread, I have detailed pictures of the correct way to use the spring compressor. I've worked on 100's of springs, and nothing keeps my attention better then a compressed spring. Not one of the car projects that goes better with some beers ..... :drink: :tsk:
    Eric J
    http://mmb.maverick.to/showthread.php?t=17503&highlight=spring+compressor
