Spark plugs help
Discussion in 'General Maverick/Comet' started by LukeLikesComets, May 21, 2022.
  1. LukeLikesComets
    LukeLikesComets Member
    Canada
    1976 Mercury Comet
    Hey guys forgive me if this is a stupid question but how can I remove these back spark plugs and ignition wires. I have a ratchet with a swivel attachment and some wire pliers but I can’t fit my pliers in to take out the wires. The only thing I can think of is removing the brake booster and master cylinder for better access but I don’t want to unless I have to. Any help would be greatly appreciated. Thanks!
  2. BruceS
    BruceS Member
    Texas
    1973 Comet
    Try the pliers from underneath the car. To install new plugs use just a ratchet a regular spark plug socket.
    Many of us have a small piece of vacuum hose in our toolbox. We use it to start the plugs.
  3. LukeLikesComets
    Canada
    1976 Mercury Comet
    Thanks a lot, I’ll give that a try, that vacuum hose is a great idea too thanks!
  4. mojo
    While your at it, looks like the vac booster hose should be replaced.
    LukeLikesComets likes this.
  5. Acornridgeman
    Wisconsin
    Flex head ratchet helps a lot to get in there.
    Where are your shock tower braces?
    Krazy Comet and LukeLikesComets like this.
  6. LukeLikesComets
    Canada
    1976 Mercury Comet
    Good call, thanks!
  7. LukeLikesComets
    Canada
    1976 Mercury Comet
    Thanks! I’ll pick one of those up, I took them off when I changed the shocks and totally forgot to put them back on. Appreciate the reminder haha
    Acornridgeman likes this.
  8. LukeLikesComets
    Canada
    1976 Mercury Comet
    I just looked to try and find a replacement hose and couldn’t find anything, Where can I buy one?
  9. mojo
    Looks like just a piece of hose; take it off and carry to parts store so can get correct diameter and length. Also, be careful removing hose from plastic connector, brittle, don't want damage it. I would slit it w/ utility knife and pull it off.
  10. LukeLikesComets
    Canada
    1976 Mercury Comet
    Will do thanks for the help!
  11. Krazy Comet
    Vacuum hose is different than hoses rated for pressure. While most work OK, the vacuum will cause some to collapse.
    I bought some awhile back, I believe was from Rockauto.
  12. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Most spark plug sockets have a 3/4" wrench head on them. That is for loosening and tightening. One reason I stay away from PB. My 68 Cougar would bring new words to my mouth.
  13. Krazy Comet
    No the older plugs require 13/16", shrank to 5/8 in latter '70s(tho not inline 6). Cleveland & 429 Cobra Jet engines introduced in '70 used the smaller plugs.
    Deep sockets with rubber inside were sold for sole purpose of plug removal.
    rickyracer likes this.
  14. rickyracer
    rickyracer Member
    Central Nevada
    You mean like these? That have the 3/4" wrench head or the universal swivel?
    Krazy Comet likes this.
  15. Krazy Comet
    Yeah but one in my tool box has a 7/8" end nut, Craftsman probably 40 years old.
