Speedhut gauges
Discussion in 'Drag Racing' started by Xplane, Apr 28, 2019.
  1. Xplane
    Xplane Member
    SoCal
    Lots
    I wasn’t sure where to post this, but figured this would work.
    I have been agonizing over how to add additional gauges without it looking like a hack job and utilizing the factory gauge bezel. After much research I decided to go with a set of speedhut custom gauges. The 4” fit perfect in the stock instrument cluster.
    I’m using a gps Speedo/8k tac and shift light. The odometer part is pretty cool cuz it will log 60 ft/1/8 & 1/4 times and speeds thru the gps. It also has high beam and turn signal leds built in.
    The other gauge had volts, oil pressure, water temp, and factory sender compatible fuel gauge. Each one has a programmable warning light you can set. They are back lit and very customizable.
    I’m going to have work make me mounting brackets with a 3D printer, and I’ll post pictures when it’s wired up and installed.
  2. yellow75
    Tillamook Oregon
    Very nice upgrade, looks like it was made for the bezel
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    That's nice!
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I like that the tach gets priority!
  5. Xplane
    Xplane Member
    SoCal
    Lots
    If you check the website you have lots of choices when configuring the gauges, I thought the speedo should take a back seat. :happy:
    https://www.speedhut.com/
    RMiller likes this.
  6. Xplane
    Xplane Member
    SoCal
    Lots
    Mount plate complete, just need to make a couple of small tabs to mount to the bezel.
    apso1857 and mojo like this.
  7. RMiller
    Kennewick, WA
    You know you could sell a bunch of those plates if you wanted to!
  8. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    I would possibly be interested in buying 1.
  9. mavgrab302
    Love my Speedhut gauges..
  10. Xplane
    Xplane Member
    SoCal
    Lots
    I’ll put together some info on how I mounted the gauges, in case anyone wants to do something similar.
    canuck222 likes this.
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
  12. Xplane
    Xplane Member
    SoCal
    Lots
    Some info for anyone wanting to do something similar to this speed hut gauge installation.
    I sheared a piece of .050 thick 2024 aluminum from scrap at work. Dimensions I used were 12.5”x5.25”. I bought a 3.875” metal hole saw from amazon and measured, centered, and bored the two gauge holes. The gauges are held to the plate with a threaded collar that comes with the gauges.
    Next I drilled 6 each holes evenly around the perimeter of the gauges. Make sure you plan enough edge distance not to interfere with the gauge collar or any of the structural ribs in the gauge bezel. I deburred, radiused the corners, and painted the plate flat black.
    I used 6 ea 3/16” all thread button head screws with washer under the head and self locking nut to spread the load out against the fragile gauge bezel. Just snug the fasteners so the plate is secure, don’t over tighten them. The spacers I used between the gauge plate and the bezel are 11/16” long, that perfectly placed the gauges even with the bezel.
    The gauges as I configured them have what I wanted to display, I have another small lcd display that is hidden under the dash that will swing down and display other important information regarding the nitrous system when it’s needed. I removed the factory harness and removed all the wiring for systems or options I’m not using(was a LOT of wiring I removed). I cut, crimped, and installed solid pin sealed deutsch connectors connecting the new gauges to the original harness. I actually completely did away with the original fuse box and am using a marine type fused and bused aftermarket box. I had additional circuits and relays from the aftermarket components I built and mounted where the heater box used to be up under the dash.
    With a one wire alternator and the battery in the trunk I only have 5 wires from the original harness running to the front of the car. I routed these thru a new sealed deutsch firewall connector and harness that now runs completely out of sight through the left fender well.
    I am making the clips today to mount the gauge bezel assembly to the dash bezel. I will detail that when it’s complete.
    Below are some pictures for clarification, let me know if you have questions or need more detail. I plan to put all the stock controls, vent, etc back in the dash so it looks mostly stock except for the gauges and the switch panel where the radio will be. I do not plan to reinstall the tray. Please excuse the wiring it is a work in progress, everything will be routed, wrapped, and clamped when it’s done.
    Mike
    DFE463DF-A19C-42DB-B170-317F8F376EE4.jpeg 095973C0-3E5F-44E4-AA6B-E6115BE55C41.jpeg B65B9D22-3A03-42F8-B68B-34BC68729430.jpeg 97305973-B182-4F51-8CD7-B8D6397C0799.jpeg 204A511B-72C7-492B-A855-75588078EB25.jpeg F8AB3B19-932B-424C-B8BD-FBB9E732F015.jpeg D3B1FA19-35C5-4AB5-A2EF-38B27A7D6853.jpeg
  13. dyent
    dyent Member
    vancouver bc
    Thanks for the great write up so far! Looking forward to seeing more as you progress.
    David
  14. Xplane
    Xplane Member
    SoCal
    Lots
    Fabricated two small tabs and ended up using 4 each 6/32 studs cut to length which thread into the instrument cluster perfectly. Custom cut spacers to keep from putting stress on the instrument cluster or bezel. I just need to drill the clips and plate I made for a two blind rivets per clip. It appears to be very solid and I’m happy with how it turned out.
    0AE80237-6CD1-4956-92CD-DCF28585A9E4.jpeg 05704B89-3302-462C-9585-42953CEDF941.jpeg F784CE92-BC2A-438E-9DB2-D39530A0554F.jpeg
    apso1857 and mavgrab302 like this.
  15. RMiller
    Kennewick, WA
    Did you use the factory lens or leave it out? Hard to tell from the pictures.
