Speedometer Cable hole blank for C4
Discussion in 'General Maverick/Comet' started by smegnl, Aug 8, 2020.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    do they make such an animal? I looked and looked. I could find them for a bunch of other trans, but not a C4.
    I bought a el Chepo sepedo cable and was just gonna hack the end of it off, but it doesnt seem to want to go in the hole.
    https://www.summitracing.com/parts/atp-y856/questionsanswers#qa-display-detail
    I dont know if there is pressure at the hole or if i can just get a freeze plug or rubber adjustable plug and shove it in there.
    Thank in advance.
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    No direct pressure there. The rubber plug should work if you can find the right size.
  3. Krazy Comet
    AFAIK speedo cable opening on Ford transmissions from at least early '60s through early '90s are all same.
    Incl C4, C6, T-5, AOD etc etc
  4. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  6. Craig Selvey
    I have to ask.....what are you doing for a speedo cable?
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    My money is on a GPS speedometer. I like the idea but there are areas here where you will lose signal along with all all your readings.
  8. Krazy Comet
    Install a backup system....
    stumanchu and RMiller like this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    yep. Gonna go that direction.
