Speedometer gear
Discussion in 'Transmissions' started by Johng1970, Apr 4, 2016.
  1. Johng1970
    Johng1970 Member
    Freeport, PA
    I put 355 gears with a 3 speed transmission, How many teeth does the speedometer gear need to be?
  2. 71gold
    what size tires?
  3. stuarta
    stuarta Member
    Moose Jaw Saskatchewan
    2008 Ranger
    What gears were in it before?
  4. Johng1970
    Johng1970 Member
    Freeport, PA
    P 205/70 R 14
  5. Johng1970
    Johng1970 Member
    Freeport, PA
    Don't know. I don't have the rear end anymore. Had to scrap it
  6. stuarta
    stuarta Member
    2008 Ranger
    Was it more? Less?
    It will be trial and error.
    71gold likes this.
  7. 71gold
    are you planing on keeping these on the rear?
  8. Hotrock
    Munroe Falls, Ohio
  9. Krazy Comet
    Dismal Swamp
    Each tooth added to gear will decrease reading at 60mph by approx 3 to 3.5 mph... By same token each one removed will increase reading by same... Because of the 255 tires I had to switch from orig 20 to a 18T gear to correct reading in my Comet...
    Drive gear on output shaft, tire size & axle ratio are all variables on this rule of thumb...
  10. Johng1970
    Johng1970 Member
    Freeport, PA
    yes
