Speedometer Gear
Discussion in 'Technical' started by Ford Guy, Mar 15, 2007.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I spoke to a tranny shop yesterday and they said to get it right they would have to put the car on a dyno. He said he would have to make another gear because it was a ford. Where can you buy another gear for the cable. Does the gear come off the end of the cable or does the whole cable need to be replaced?
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Just us lazy people. :bouncy:
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Jeff's Bronco Graveyard has the whole selection of gears. Good prices. Ford still has the gears. You may have to have the part number to find them. Do a search on the net, lots of info an part # for this
    Take a drive on the interstate. 60 seconds for one mile is 60 mph.
    Russell likes this.
  4. Grabber5.0
    Kansas City, MO
    71 Grabber
    That sounds like crazy talk. :D There is a clip holding the gear on the end of the cable, very easy to replace. I'm pretty sure you can get them at a Ford dealer. TCI lists part numbers, but when I tried to check pricing or add one to my cart it gave me an error, so I'm not sure if they actually carry them or not. Wouldn't hurt to call a speedometer calibration shop or some dealers near you. You need to to know the # of teeth on your current gear, your stock rear gear ratio, stock tire size, and new tire size if you have changed tires. There are lots of gear change calculators on the net if you do a search.
  5. baddad457
    Mustangs Unlimited also sells the gears. As does your local Ford Parts dept.
  6. baddad457
    Sounds like the second case of a shop trying to "stick it" to the customer I've seen this morning. Find another shop to do business with .;) Ford's used the same speedo gears on all their cars and trucks from the 50's till they went to electronic speedo's in the 90's.
  7. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Also one more question, I have seen two different types of gears. One is called the "driven" gear but I'm not sure what the other one is called. Is the "driven" gear the one that I need?
    Thanks,
    Ford Guy
  8. bmcdaniel
    Yes, the driven gear is the one on the cable, the drive gear is the on the shaft.
  9. Mavaholic
    I bought mine at Ford for about $8.
  10. Mavaholic
    Here is the chart with all the part numbers. Take the first 4 digits from the gear needed, add the 17271, then the last digit from the gear needed. Example: If you needed a 16 tooth for a manual, the part number would be: C0DZ17271A
  11. baddad457
    There's also a 23 tooth gear you can add to that list. I think this one maybe an aftermarket item though. Mustangs Unlimited is one source for these.
  12. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    I used bmcdaniel's method and i calculated the percent of error to be around 24%. How many teeth do I need to add or subract to have the correct one?
  13. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    I forgot to say that according to the tachometer i was going 50 mph but my speedo said that I was going 62.
    -Ford Guy
  14. baddad457
    You need a 20 tooth gear. 7 X 3.55 X 807 = 20,054, divide that by 1000 and you get 20.
  15. yellowgrabber
    yellowgrabber Member
    Camano Island, WA
    72 Maverick Grabber, 61 Falcon Futura V8 363ci Dart Block, 62 Falcon V8 289ci toploader
    Here is a site I ran across setting up my 72 Grabber... takes most of the guess work out of it.
    http://www.428cobrajet.org/speedo-calc.html
    I remember there was another calculator I had found that was also useful that included overdrive tranny calculations... will try to find it.
