spindles
Discussion in 'General Maverick/Comet' started by Shadow750, May 21, 2024.
  1. Shadow750
    Shadow750 Member
    NC
    Does anyone know if 67 mustang spindles will work on my 70 Maverick? Someone said yes but with different tie rod ends. Very confusing. Also, someone said that the original 6 cyl spindles will work with the 5 lug v8 hub. Is that true?
    any help would be appreciated.
  2. bmcdaniel
    All Maverick drum brake spindles are the same as '70 Mustang drum spindles. You can put bigger brakes and 5-lug hubs from a '70 Mustang or later Maverick on your car.
  3. Shadow750
    Shadow750 Member
    NC
    Thanks man. But I already have the 67 Mustang drum spindles. I am going to use the right stuff aftermarket disc brake kit. It bolts right on. Krazy Comet told me the 67 mustang spindles will work as long as I use the 67 mustang outer tie rod ends. Do you agree?
  4. bmcdaniel
    No personal experience with '67 Mustang spindles, but Krazy has the interchange manuals so he should know.
