Spits and Sputters horribly at WOT
Discussion in 'Technical' started by scooper77515, Mar 1, 2006.
  1. 71gold
    :Welcome:...:Handshake:
  2. Krazy Comet
    Well it'd sure help to know what engine, carb ignition system ect...
  3. lahrs37
    lahrs37 Member
    Philadelphia
    Big Block, HEI, Holley 750. 36 degrees at 3000 RPM. Mixture screws adjusted pulling 17 in of vacuum. No vacuum leaks that ai can find after spraying carb cleaner everywhere. put on a spare 650 Holley that was known to work and nothing. Floats adjusted property. Fuel pump replaced. Filter replaced. HEI swapped out for a different known working HEI. Replaced PCF valve and breather. It's a new build.
  4. Krazy Comet
    Does it rev cleanly without load? Does vacuum remain steady under light acceleration, say 5-10"?
    By steady I mean not fluttering,
  5. lahrs37
    lahrs37 Member
    Philadelphia
    It does rev cleanly without load. I would have to run a vacuum line into the car to check it under acceleration
  6. lastchance
    lastchance Member
    Hingham , Massachusetts
    Had similar problem ,Discovered air cleaner was too small.Sounds crazy but it cured mine.
  7. Krazy Comet
    I'd check vac, possibly it has a exhaust cam lobe going flat, valve hanging etc. If vac flutters & swings toward pressure, cylinder isn't being evacuated on exhaust stroke. In that condition idle/no load is generally OK, but under power spits back into intake.
  8. lahrs37
    lahrs37 Member
    Philadelphia
    Ok, that is worth checking. I just was fooling around with it at lunch and it actually starts popping a above 3000 rpm when I rev it in neutral. Didn't notice it when I was setting timing because I only revved to 3000 RPM.
  9. lahrs37
    lahrs37 Member
    Philadelphia
    I have driven it with no air cleaner at all and that didn't change anything.
  10. lahrs37
    lahrs37 Member
    Philadelphia
    You nailed it. Vac was fluttering. Our a dial gauge on the lifters and found 2 wiped out exhaust cam lobes. Thanks for the insight. Looks like it is time to pull the engine and see how much damage I did.
  11. Krazy Comet
    Sorry to hear a new engine is giving problem, unfortunately it happens.
  12. scooper77515
    I ended up going MUCH richer, and it pretty much stopped sputtering. That said, I ended up going with a much larger carb.
    Sorry for the late response, I don't get on this site as much as I used to.
