Sport Lamps - 72 grabber
Discussion in 'Technical' started by TrotMaverick, Aug 3, 2011.
  1. Craig Selvey
    I would say this is your problem.
  2. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    Hmmm...Not sure how to wire in a ground on the driver side....
  3. Dave B
    There is a ground on each side.
  4. Craig Selvey
    Exactly. You need to find it and attached another wire to it...then ground it.
  5. TrotMaverick
    Gaston, Oregon
    I'll look around, but might have to get help with that one.
    The driver side has never worked, not since i've owned it anyway.
  6. TrotMaverick
    Gaston, Oregon
    I still see a bolt where it should be, but when i had it off i dont recall seeing the ground wire. i'll look again though and actually look for that.
  7. injectedmav
    injectedmav Member
    Georgia
    the wire could be broken or someone could have tucked it back into the loom. Both of mine are mounted just below the level of the gravel pan on the radiator support. I moved them higher in another hole, but mine didn't come with the sport lamps, I just had turn signals. I added the sport lights.
  8. maverickfever
    maverickfever maverickfever
    Winnsboro SC
    26 Mavs and Comets
    I hope not to over step here but maybe this will help.If it is the driver side on a 72 grabber my car is as this'three wires from sport light goes to junctiondown to two wires to plug to harness plug just out side of radiator support.the ground wire actually come from the engine side of the rad. support and is two wires together. a round eye end connects them to the car.,only comes threw maybe 6 to8 inches long.5/16 or so bolt maybe 2 inches from the radiator opening.If it would help i can email pics to you. I cant seem to get from phone to here.Thats all i got.
  9. maverickfever
    Winnsboro SC
    26 Mavs and Comets
    your car looks like my car,or does mine look like yours ???
  10. TrotMaverick
    Gaston, Oregon
    Yours definitely looks like mine. ;) Go ahead and e-mail them to me...Trotterman356@hotmail.com.
    Or if it's easier you can send them to my phone 503-476-2719....No stalkers now.
  11. TrotMaverick
    Gaston, Oregon
    Thanks for the pic...More good news/bad news. The ground is there, however that means i have a different problem for why my sport lamp doesn't turn on. :( time to wiggle!
  12. TrotMaverick
    Gaston, Oregon
    Hmmm, The light is on now but very dull...Doesn't make sense to me since both bulbs are brand new and exactly the same...any thoughts?
  13. maverickfever
    Winnsboro SC
    26 Mavs and Comets
    Maybe bad connection on bulb socket or ground.
  14. TrotMaverick
    Gaston, Oregon
    hmmm...Might have to have my old man take a look, he knows a lot more than i do. i'll tweak with it a bit and see if i can get anything though.
  15. maverickfever
    Winnsboro SC
    26 Mavs and Comets
    may take the ground loose,sandpaper the ground end and where it bolts to.after you bolt back to car make sure you shoot a spot of paint back on the area too protect from rust if you do.i had corrosion in my ground on pass side.
