Sport mirror rebuild
Discussion in 'General Maverick/Comet' started by 74 GRABBER, Jan 17, 2011.
  1. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    Any one have any info on rebuilding sport mirrors? Mine are in good shape, but are "floppy" so to speak. You can tap on the housing with your hand and the will kinda fall down and not stay in the position you set them at. Not functional mirrors at all. LOL
    Just wondering if someone has taken them apart and would care to shed some light on dismantling them and getting them tightened up.
    Thank You :)
  2. Earl Branham
    Lugoff, SC
    Check the set screw inside the mirror. Just move the glass to one side, and use a screwdriver to tighten the screw. Mine loosens up from time to time. Put a drop of locktite on it, and it should stay put. Don't know about rebuilding them. I do know the glass is available. Good luck!
  3. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    wish i could find someone with a drivers side gasket for the remote sport mirror.
  4. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    Thanks for the heads up, I will give that a try I was thinking it was going to be something in the remote assembly that needed tightened up.
    I never took one apart before, just trying to get some info so not going into it blind
  5. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    Did you try emailing Craig?
  6. CaptainComet
    Autokrafters supposedly has a good source for mirror gaskets now. They had problems before but allegedly that has been rectified.
  7. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    no i did not. i did post a long time ago in parts wanted. thats how i got that gasket from some idiot that fits a mirror from a 55 edsel:(
  8. rickm
    rickm Member
    Owosso Mi
    74 Heres what I did with a loose mirror and it's holding fine. I put the car in the garage and found the setting I wanted by meassuring every angle I could and marking this spot on the inside of the garage door. I looked out the drivers side to get a height and so on. When I found the position I thought I want I mixed up some 20 minute epoxy glue. After removering the mirror I put alittle on the center ball, reinstalled the mirror and set it with a yard stick as I sat in the drivers seat. ONLY use a little glue at this time ! ! ! Now after it has set up drive the car around and make sure you are happy with your mirror placement. If not you can remove it and break it free ( thats why you only used a little ) and reset it and try again. When you fine the best place you remove the mirror and glue the hell out of it !. I have epoxy around the whole ball and on both side pins and it's holding just fine. Thats the only fix I could come up with. Good luck Rick
  9. Acornridgeman
    Wisconsin
    I just fixed one of these for the drivers side. All the remote cables were OK, just had poor friction on the ball. I carefully cleaned out the ball and socket area of all the old sticky grease. Then repacked the area with 3M autobody chaulk. That stuff is very sticky and doesn't harden up. That seems to have done the trick as the mirror moves with the remote on all 3 axis and is firm enough now not to move on its own.
    (y)
  10. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    My passenger side, non-remote sport mirror was flopping around. I removed the mirror from the housing, stripped about 1/2" of insulation off of some #12 house wiring and slipped the insulation over one of the pins that are supposed to provide some friction to hold it in adjustment. Worked great and its still adjustable.
  11. Acornridgeman
    Wisconsin
    Great idea ...... :idea: .... !
    I thought about trying something similar. I have a bunch of that shrink tubing used to cover wire after splicing. Thought about cutting one of those and slipping it onto the guide pin then shinking it tight with the heat gun.
  12. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Clever---got that one filed away!:thumbs2:
  13. Jsarnold
    '72 Sprint
    Since the topic is active again in another thread, I'll report that this "fix" only worked for a little while. :(
  14. 71gold
