Sputtering
Discussion in 'Technical' started by Vinchez78, Aug 25, 2018.
  1. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    So I take it it's cheaper as well??
  2. Krazy Comet
    Not that I generally agree with the majority, I'd bet the mechanic is blowing smoke. If it ran OK for three days, my guess there is trash in tank that's getting into carb.
    Last year I rebuilt the carb I use on my 428, mfgr'd in 1967, runs perfectly. Always has for approx ten years, then needs freshening. . The new Holley on Comet developed a leak that showed up a year after I got it(was a free replacement for a carb that had casting problem). Anyway I had the thing apart four or five times till I got it fixed, found a internal passage plug that was improperly installed. That's something that's never supposed to need work.
    Of course when you have someone else performing the work, you are at their mercy.
  3. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    Ya true, I'm taking it back tomorrow, didn't have time to today
  4. 71gold
    I'm with Tom...cleaning the tank, lines and new filter should have been the first things the mechanic should have addressed before he even messed with the carb...JMO
  5. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    Damn, I did replace the fuel filter when I first got the car, is cleaning the tank hard to do urself?
  6. 71gold
    it's not that bad after the first time...are you pretty good wrenching?
    hardest part is getting the gas out to start with. that's why when I pull a tank for the first time I have a drain plug installed... it's an O2 sensor bung with an oil pan plug in it.
    to start with after draining the gas, take the filler neck out, you will have to remove it to pull the tank anyway. shine a light into the tank and see if there is anything in the bottom of the tank...rust, sludge for a few things that could be a problem. also take a mirror and inspect the sending unit to see if the sock is still attached to the tube.
    if you go there let us know what you find.
    Frank
  7. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    Thanks guys I really appreciate all the info, love these cars! Wish I woulda had one way sooner, I'm actually lookin for a another one with a 302 v8 in it
  8. 71gold
    the one you have looks pretty clean. you just need a 5.0, C4 and a few brackets...:thumbs2:
  9. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    Thanks man, ya would love to have those parts, just need time and the funds ofcourse, lol
