Starter help!
Discussion in 'Technical' started by FordCountry180, May 29, 2010.
  1. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    I picked up the 164 tooth flexplate, but the holes for the converter don't line up!!:(
  2. FordCountry180
    Parkesburg, PA
    Do you I think i'm gonna need the smaller bell housing or what????
  3. FordCountry180
    Parkesburg, PA
    Update
    I actually found a small c4 bell housing and it looks like the fix! Now if anyone has a separator plate that fits a small c4 i need one! Preferably a nice one with an inspection cover. Reply or PM me if you have one or know where I can find one, thanks.
  4. justin has a 74
    kentucky
    That jack is NOT safe LOL!!!!!
    Did we mention you are going to need a converter too:hide:
  5. FordCountry180
    Parkesburg, PA
    Don't worry i didn't crawl under there like that!:jack: nah, the converters ok, its just the bell housing that was wrong. I'll be using the 157 tooth flexplate and the same converter, just had the wrong bellhousing.
  6. rthomas771
    ...:hmmm:...
  7. justin has a 74
    kentucky
    Exactly:huh:
    That converter isnt going to work if it was bolted up to a 157 tooth flex and your trying to use a 164 tooth:16suspect
  8. FordCountry180
    Parkesburg, PA
    I'm sticking with the 157 tooth flexplate, and a smaller bellhousing, i had the wrong bell housing all along. Before we thought i needed the 164 tooth but its not the case. thanks for looking out for me though.(y)
  9. justin has a 74
    kentucky
    ok :thumbs2:
    good luck
