Starter Solenoid Wires
Discussion in 'Technical' started by kukm66, Nov 22, 2007.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    The 2 smaller wires hooked to the solenoid have different color rubber boots. One is blue and the other is black but the wires on both are red/blue. Which one is hooked to the battery side?
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    The battery side should only have power when the key is turned to start. The other side should have power with the key on (i believe).
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The solenoid should be marked "S" and "I".
    The "I" gets the wire that is hot with the key on.
    The "S" gets the wire that is hot when the key is turned to activate the starter.
    If the solenoid is not marked as such...
    I believe, from memory, that the "S" terminal is the one closest to the battery.
    The "I" terminal would be the one on the starter cable side.
  4. rayzorsharp
    The boots on mine are blue and green. The blue one is on the front side...closest to the battery.
