Starter upgrade
Discussion in 'Technical' started by Hairy W Bush, Jul 22, 2017.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    I bought a later model PMGR starter that was supposed to fit an early 302 with manual transmission. Well it didn't. The nose on it measures 4.135 and the hole on my plate is 4.090. I called the company and the guy I spoke to was no help, other than return it. So while I get that returned, what have you guys used that's good for not a whole lot of $? i have a 302 with the 3 speed manual
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    I went to junk yard got a late model starter from a e150 van with a 5.8 in it ... I am using a AOD trans
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    k still unsure if that will work for me
  4. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I got the new starter in. In the little pamphlet they give you it shows a fusible link and/or fuse in the curcuit. Is it necessary to put a fusible link in the wire going to the little stud on the solenoid?
  5. spork1o1
    spork1o1 Member
    Michigan
    Where is the starter ring gear at on your flywheel?
    Is it on the block side edge or on the edge closest the trans?
  6. Krazy Comet
    Unless the Ranger starter harness I used in my Comet has a fuse link, I don't have one in mine...
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    not sure what you're asking sorry. If I had to guess i think it's the first one.
  8. spork1o1
    spork1o1 Member
    Michigan
    Ford used a shallow and a deep starter.
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    first one
