Starting issue
Discussion in 'Technical' started by Greekbuckeye, Mar 11, 2024.
  1. Greekbuckeye
    Greekbuckeye Member
    Piqua, oh
    1970 Ford Maverick
    Hello all,
    I have a 70 Maverick 250ci and whenever I try to start it I get a click and that's it. After it clicks, i turn it and get nothing but it takes a while before it will click again. I'm not sure the best way to proceed. I just got a new battery but it was doing that with the old battery too (it was leaking). Your help is greatly appreciated.
  2. Krazy Comet
    One click generally indicates starter solenoid is engaging but either isn't suppling voltage to starter, or starter is defective. Proper way to troubleshoot, check to see if there is voltage on starter post of solenoid when key is turned to start. Or you can fire the parts cannon and just replace solenoid. If that doesn't fix it, probably defective starter.
    Greekbuckeye likes this.
  3. Greekbuckeye
    Greekbuckeye Member
    Piqua, oh
    1970 Ford Maverick
    So now it seems when I try to start it all the power goes out and won't come back for a time. Is there a fuse somewhere that is causing this or could this be the starter solenoid? I've ordered a new one but am loathe to replace parts if I don't have to as money is kind of tight.
  4. Krazy Comet
    Battery, dirty posts or the cables may be defective or loose. Most of this will be addressed when solenoid is installed, be sure negative cable is clean & tight on block.
    mojo and TeeEl like this.
  5. Greekbuckeye
    Greekbuckeye Member
    Piqua, oh
    1970 Ford Maverick
    I appreciate all of your help. The solenoid fixed the problem and now she runs again. On to the next problem that comes up, as they do.
