Starting work on the 72 comet after a long delay
Discussion in 'Maverick/Comet Projects' started by Lucifer, Oct 21, 2021.
  1. Lucifer
    Lucifer Member
    Canada
    1972 comet
    Paint the engine bay so I can install 347 stroker done install clutch pedal and parts pertaining too it ..install master brake for disk drum conversion and a home made bracket to hold proportioning valve and clutch master oil Reservoir
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Looks good. I used a similar master cylinder on mine, going four wheel disc so I bought an early third gen Vette part. Ended up having to open op the mounting holes to fit the studs on the car.
  3. Lucifer
    Lucifer Member
    Canada
    1972 comet
    I think this is a generic maybe gm master . I ordered a push rod it didn’t fit. I tried removing the one out of the original master and I buggered it . I had a 69 cougar power I managed to gently cut apart and it worked out. I was wondering if I should have a adjustment for my rear drums I see they have something out there for adjustment?
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Looking good!
