Starts fine, than dies after five minutes
Discussion in 'Technical' started by Red 5, Dec 20, 2014.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Make sure the choke is not set too rich. That could also cause what you are describing.
  2. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I've fixed that same issue on two different cars. First was a 66 mustang, 200 i6. The fix was a float issue, I took the carb apart and reset the floats. Problem solved.
    The second car was a 71 comet, 302. It had the same issues and the fix was replacing the coil. No issue since the coil was replaced. The next time it dies on you immediately check the coil for spark to rule that out as others have said. Good luck
  3. rthomas771
    A bad ignition switch, bad solenoid or bad ground will also produce no spark from the coil.
  4. 7D2 Grabber
    7D2 Grabber Member
    True, rules out a possible fuel issue like I had in the mustang.
