Steering box... should I or not...
Discussion in 'Technical' started by the muss, Jul 23, 2016.
  1. the muss
    the muss Member
    norway
    1970 maverick with 351 w
    This forum rocks Krazy comet had the solution for me. Under the endcap the nut Was completly loose. Tightening it work for me. No more sloppy steering.
  2. Krazy Comet
    Ahhh, glad it was that simple....
    When the preload is badly misadjusted it's possible for ball stud it pop out of valve, meaning you'd have no steering...
    It's a common misconception driving wothout P/S operational will cause it to pop out, but only if it's badly worn and/or misadjusted... A valve without excessive wear and proper preload will not come apart...
    LukeDuke and the muss like this.
