Steering columb interchange
Discussion in 'Parts Interchange' started by Survival276, Aug 19, 2008.
  1. Survival276
    Survival276 Member
    London United Kingdom
    I have a 1970 200ci Maverick with columb shift non locking and ignition key on the dash. Now after removing my original steering columb, i think it has come to the end of its life,(i maybe wrong). The problem i'm having is I live in the UK and i have one of about 3 mavericks that i've seen in the country. Mustangs on the other hand are plentiful. My question, is there a mustang or another columb that i can use in its place? Or a company suppling aftermarket columbs that will fit? Or you may have one for sale?
    Thanks
  2. Dave B
    Nope, you'll need to find another Maverick one.
  3. Mavaholic
  4. Jamie Miles
    Sorry to get off topic, but I gotta say, man that is a cool car you have. Not only is it likely the only '69.5 in the UK, you probably have the only right hand drive '69.5 in existence! Very neat car! I'd love to see the VIN and other codes on that car.
    And just for reference, if you do try to get another used column, you need to be sure to get one for a '69.5. The later '70 column will not work. I wonder if there is any difference in your column, being that the car is RHD?
  5. rayzorsharp
    How would you like to buy a nice dash pad off eBay and open the box to find out it came off a RHD Maverick! :hmmm:
  6. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    Where was this car manufactured. Can you still buy steering parts for the car. Like steering box, idler arm, drag link. If you can, we over in the US can make a right hand drive very simple. This is something i have thought of many times.
  7. Jamie Miles
    What would you do for the dash? The dash in that car looks like it came from the factory like that to me. Finding another RHD dash would probably be near impossible?
  8. Mavman72
    with a good bit of sectioning and some fabrication you could turn a LHD into RHD.The pad would be a bit tougher.cutting and sectioning the pad would take some creativity.
  9. just1993
    just1993 Mike
    Zionsville, PA
    I have recovered my own dash pad & I know I could easily section it to make it right hand drive. Same with the dash. It would be very interesting to roll into a car show with right hand drive!!!
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Somebody at the gathering told me they used a 68 mustang column in theirs...
    He had 69.5 maverick...
    I couldn't back that up with any factual XP though. Anybody here got a stang column to compare
  11. Survival276
    Survival276 Member
    Hi guys. Sorry for getting back to you so late. My Maverick has been converted to RHD i think using australian parts, (steering gear, center link and idler arm). All have part numbers starting AR. I believe that the steering columb is original.
    I got this car from a guy in London for £350. Which i thought was cheap, but with the work i've done to it and its still not road worthy. How wrong was I.
    She still has the 200ci straight six. Soon to be a 302 V8.
    8" back axle from a 72 mustang.
    SSBC front disk brake conversion kit.
    I'll try and remember to get part numbers for the guy who asked for them. If you would like to see more pictures i'll up load some more soon. Thanks
  12. Jamie Miles
    He PM'ed me the codes off the door tag. Pretty run of the mill '69.5, except the one thing that caught my eye. The DSO is 90, which means the car was intentionally built to be exported out of the country. That's the first Maverick I've ever seen with the export DSO. It seems most of these cars that end up in other countries were exported from the U.S. by private individuals, and have DSO's matching a U.S. city.
    Other then that, it was built at the St. Thomas plant, factory 200 I6 car with a C4 trans, 7.5 rear with a 2.83:1 gear, the car was "Medium Peppermint Metallic" exterior with Black vinyl interior. It was built on Monday, June 23, 1969.
  13. Survival276
    Survival276 Member
    Thats great thanks. Is i possible to get more info from the factory on this car. Maybe it was built RHD from the start/
  14. rayzorsharp
    All of these cars like this were converted to RHD...none ever were done at the factory.
  15. HARRYJOHNSON
    HARRYJOHNSON Member
    AZ USA
    COMET 73
    rhd steering
    have you triedto rebuild yours you could probably use nost of the parts from a lefthand drive If I lived in the uk and had a rhd Comet or mav I SURE AS HELL WOULD TRY IT backburnryharry@msn.com good luck
