Steering Column Shifter
Discussion in 'Transmissions' started by 4gottenmuscle, Dec 11, 2022.
  1. 4gottenmuscle
    4gottenmuscle Gone but never 4gotten.
    Bay Point,Ca
    73 Ford Maverick
    My shifter on my 73 Ford Maverick Won't stay in Park. When I go out in Public I have to chock the rear Tire to keep it from rolling away. What do I need to do to fix this issue. And the Steering Column Shifter is very loose or sloppy like the bushings are gone possibly.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Check the pivot pin for the shift lever, it may have slipped down and is letting the lever move excessively.
  3. 4gottenmuscle
    Bay Point,Ca
    73 Ford Maverick
    Okay where would the pivot pin be located is it in the column or is it under the car near the shifter on the transmission?
  4. dyent
    dyent Member
    vancouver bc
  5. Craig Selvey
    Check to make sure the "pin" is fully seated that holds the chrome handle onto the steering column.
    RMiller likes this.
