Steering column sloppy
Discussion in 'Technical' started by buickv6, May 14, 2019.
  1. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    Is there a bearing in the steering column near the fire wall I can replace? I can move the shaft where it just enters the engine bay a half inch or so. I am not sure if I need a shaft steady bearing or pull the column to repair?
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I don't think they had one originally since the box was right there to support it but in your case I would think you would need one.
  3. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    true, does the rag joint flange come off the column shaft with a puller? That would make this easier.
  4. Krazy Comet
    Dismal Swamp
    No lower bearing, not necessary. Flange on steering shaft bolts to the rag joint, the rigidity of joint keeps shaft in place, plus aligned with steering gear shaft. Probably need a new rag joint, common replacement part.
  5. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    that clears it up for me, since I went to a mustang rack with universal joints I will have to add a support bearing because of this.
  6. RMiller
    Kennewick, WA
    I don't believe the flange comes off, probably need to pull the shaft out.
  7. 71gold
    when I cut my column for the rack n pinion I had to install a support bearing in the end of the column.
    I had pics but lost them in a puter crash.
  8. mojo
    When I cut my column for the Borgenson conversion, it didn't have a support bearing. I'm not certain it was never one there, but, everything is tight -- no issues.
  9. 71gold
    mine didn't have one either, I put one there because it came with the kit...RC 107.
  10. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    thanks, I am install a bushing in the end of the column
    mojo likes this.
