Steering gearbox adjustment
Discussion in 'Technical' started by ChadS, May 11, 2007.
  1. 71gold
    Rando,
    to what extent do..."you rebuild your own boxes"...i have looked for a "kit, seals or balls (rollers)" and can't seem to find anything .:cry:
    posting some #s would be nice...(y)
    ...:yup: ...
  2. Rando76
    Rando76 Member
    Claremore, OK
    I have replaced most everything except for the rollers.
    We need to search the boards on this. I can't remember what I posted and what I haven't. The lower seal, ball bearing, roller balls, and rollers can be purchased from most bearing shops. I have the lower bearing seal number (but not with me now). If you need it, I will find it and post it. The other numbers I don't have any more (I haven't rebuilt one in almost 2 years and have since moved). The small rubber top seal I bought from a gearbox rebuilder. It was the hardest to find. I can't remember the name of the business either. They were located in Michigan I think. I can also find this info if you need it.
    I have never found a rebuild kit. I had to buy each part individually from several sources. I spent less than $20 on parts. It's a lot cheaper than buying the boxes already rebuilt.
    The boxes are fairly easy to rebuild. Get a pan and some paint thinner to use as parts cleaner and take it apart. Make sure not to lose any of the roller bearings and to use grease when putting them back in (to hold them in place). A preliminary adjustment can be done by hand (by feel) and the final adjustment can be done after you get it on the car.
  3. Rando76
    Rando76 Member
    Claremore, OK
  4. 71gold
    did you ever call Harry and ask him what to put in after rebuild...oil/grease...?
    ...:cool: ...
  5. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Does Anyone Have Pics Of The Grese Zert On It I Looked And There Was No Pics
  6. Rando76
    Rando76 Member
    Claremore, OK
    Yes, I did. He's who told me to mix grease and heavy weight oil (like gear oil) to make a "really thin grease". That's what he uses in the boxes he rebuilds.
  7. 71gold
    P.M. Earl, he has a pic. of when we did his...or
    ...picture this...
    ...drilling a hole in the top and screwing a grease fitting into it...:yup:
    ...(y) ...
  8. 20cows
    20cows Member
    West Texas
    74 Maverick
    Uh, he DID take the top off while he was a' drillin' didn't he?:49:
  9. 71gold
    ...:yup:...
    ...:cool: ...
