Steering Rebuild
Discussion in 'General Maverick/Comet' started by Mobiledreams, May 10, 2020.
  1. Mobiledreams
    Mobiledreams Member Supporting Member
    Buffalo WV
    1976 Maverick
    Maverick felt like I was driving a bumper car. Just finished the front suspension. So on to the steering. I have the inner and outer tie rods and adjusters and the idler arm. Looking for a Manufacturer of the center steering bar, and the power steering unit itself. Anyone out there know if they make a steering box for the Maverick that has a tighter ratio than the stock 16:1? or if one fits from another ford?
  2. ike72com
    ike72com Member
    Charleston SC
    Have you gotten an alignment yet?
    I did complete front suspension as well on comet but have not been on road yet.
    I recalled from suspension rebuild on my mustang that car was wobbly after suspension rebuild. After an alignment things where good to go afterwards.
  3. Krazy Comet
  4. Mobiledreams
    Buffalo WV
    1976 Maverick
    I was going to wait until I finishe the steering to do the alignment but may I'll do that first. Thanks
  5. Mobiledreams
    Buffalo WV
    1976 Maverick
    Too bad. 16: 1 it is then for the steering box. I'll pull the center link and see if theres bushings that can be replaced to recondition the old one. Just worried about 45 years of age wallowing out the holes where the tie rods and power steering arm connect. Thanks for the info
  6. Krazy Comet
    In 50+ years of vehicle ownership, I'm yet to see Ford vehicle with looseness in the tie rod or power cylinder mounting. Bent, now that's a different story.
    Mobiledreams and mvw66gt like this.
  7. Mobiledreams
    Buffalo WV
    1976 Maverick
    I took a look at the thread where you have all the parts laid out. looks like the way to go. I have everything but a cylinder rebuild kit or a new cylinder. I'll get started right after I reverse those bushings on the strut rods. Thanks again.
  8. Craig Selvey
    I agree....your center link will not have any "wear".
    In rebuilding the steering parts (ie, slave cylinder, control valve) I suggest you rebuild the ones you have. Google Rodes Restorations in Galion, Ohio. They can rebuild all your old parts.
    Mobiledreams likes this.
  9. rthomas771
  10. Mobiledreams
    Buffalo WV
    1976 Maverick
    Went to the link Melvins has alot of great stuff. Wife caught me looking at what she calls parts Porn, shook her head and slowly backed away.
  11. mojo
    Wait till u get all suspension/steering completed B4 getting alignment; that way, u'll only need to do it once...
    Mobiledreams and Krazy Comet like this.
  12. maverick600
    maverick600 Member
    San Angelo, Texas
    You can use a tape measure on the inside of your backing plates on the front wheel to get the toe adjusted close to correct. Take measurements in front of wheel and behind the wheel. Adjust accordingly to get your width between front and back close. Alignment shop can zero it in while adjusting the rest.
