Step by Step Fuel Filter Change (in the tank) for Dummies
Discussion in 'Technical' started by gdemopesq, Mar 10, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    You gents are the best
  2. Dave B
    You know what, I was just reading an article in "Mustangs & Fords" about fuel systems, and they say to get rid of it all together, no in tank filter.
  3. blugene
    Buy a new sock and "O" ring gasket from autokrafters, there cheap. Put new rubber fuel hoses on too... And like mentioned, shake the float and see if it has anything in it. Order that also from AK if it does. :)
  4. 71gold
    ...and the reason to delete :huh:...
  5. Mavman72
    Impedes flow(A tiny bit)Instead of tearing the fuel strainer off the pick up tube,use a tubing cutter and take just enough tube to remove the strainer.
  6. 71gold
    might not want to "cut" any off the tube...it will be out of gas before the guage reads empty...
    ...JMO...
  7. Mavman72
    True but if he is going to put hose on the end w/a filter,he can make it any length he wants.(just dont want to see him mangle the tube if he cant get the strainer off):bouncy:
  8. PaulS
    Putting a filter on the end of the fuel pickup is just making it easier to clog and have problems. Leave the in-tank filter off completely and put a large filter between the fuel line and pump. That way when it clogs you can replace it withouthaving to drain the tank, jack the car...etc.
  9. rebelgt
    rebelgt Member
    Southeast Missouri
    1972 Comet GT
    We put a new sending unit and cooked the tank out last year, and the sock still stopped up. So we are now sockless, and using a inline filter before the pump and one after the pump, just for safety sake. Runs like a champ. Inlines are easier to change than tank filters.
