Stick built vs metal garage
Discussion in 'Tool & Shop Talk' started by stoney, Apr 30, 2020.
  1. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    How many of you built your own garage vs purchasing metal building, what are pros/cons with 2 door, single door?
  2. Fastkarz
    Fastkarz Member
    Northern NJ
    1972 Maverick Grabber 347/AOD/4.11
    Doors.jpg I put up a 1480 sq' 2x6 stick frame garage. On paper it holds 3 cars, in reality I have had 6 in there. I installed two garage doors, one normal 10' and one oversize 14' wide by 12' tall to accommodate a truck with ladder rack. If I did it again I would have used two over sized doors instead of one small door and reduced the space between the two doors. I find it easier to swing cars in the oversize door.
  3. Powerband
    Powerband Member
    NY's \H/
    About what size and whats going in it ? ...
    If a work-in garage, handy to have separate man door in front. if mainly for car storage , for me more car doors the better . Small or big, won't take long to fill .
    In this area Pole Barns are typical.
    [​IMG] . [​IMG]
    have fun
    mojo likes this.
  4. mojo
    What type of floor does the barn have? Not seeing a concrete slab!
  5. Powerband
    Powerband Member
    NY's \H/
    A feature about traditional Pole Barns' is no floor is typically required in construction, even in regulated zoning areas. Technically the Poles into undisturbed earth are considered the 'foundation' .
    Traditionally you start with one hole and move corners until fairly square. Then poles are added in between - anywhere you don't hit too big a rock to pullout, they don't even need to be even.
    Laminated wood - spliced poles are revolutionizing the construction, long poles not required ...
    For floor a PT 'band' is simply placed around outside bottom of poles and concrete poured as needed. Most for Ag use don't more than gravel.
    Planed and sealed concrete
    [​IMG] / [​IMG]
  6. mojo
    That's a very nice setup! Never thought much about a Pole Barn different from large/oversize garage -- Thanks for clarification. So, typically, a slab is poured, only if requested? What's sq. footage?
    Falcenac likes this.
  7. Powerband
    Powerband Member
    NY's \H/
    Yes only if requested or required, I have a Blacktop paved floor in another barn - sq footage - Size is the thickness of your wallet and local ordinances ... use 24X36 work barn, 32x36 dry clean car storage.
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Unfortunately a work transfer took away my 28' x 30' wood frame garage. I got a great price on it by finding a place that factory built the walls. It had an 8' door and a 16' door plus a man door on one of the end walls. Room to pull cars in and still have workbenches across the back wall.
