Stripping and screwing the hole!
Discussion in 'Technical' started by blugene, Jul 25, 2006.
  1. stmanser
    Davenport, Iowa
    yeah 71gold, that is a great idea.. thanks for the tip.. :)
  2. Jamie Miles
    Alto, GA
    I've had a few
    (Yea, god forbid they be exposed to reality.)
  3. blugene
    That's what I ment to say...:D
  4. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    Blugene, the hole should not be hard to figure out...take one of the other bolts and use a thread gauge and just measure it,probably a 7/16 course.
  5. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    If a one size up bolt will fit through the hole I would just oversize the thread and call it a day. Heli-coils are great for aluminum and mag and stuff, but I like to use parent metal as much as possible on steel and cast iron. Just one less thing to go wrong. Threaded inserts are the best way to go a lot of the times as long as the prep hole doesn't put you into a thin material condition anywhere.
  6. blugene
    That's what it is, but only for the last about three threads. I will have to go bigger, I have the bolts that I am thinking I want to use. I won't get to get back on this untill mid week. Been sick the past couple of days. Kinda over did it the one night when the first mount and I fought for about six hours:mad: . I finaly kicked its azz, but the other side is trying me. I have about two hours on the second side so far. By no means am I bragging, cause that is actually embarrising. There was a time when I would have something like this knocked out in an hour for both sides, now i'm bragging,:biglaugh: .
    [​IMG] [​IMG] I need more nyquill, later.
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Are you saying only the first 3 threads are messed up? If so have you considered using a stud? (goes along great with the thread title)
  8. blugene
    :lolup:
    No, the last three.:(
  9. blugene
    Ok, I now have a tap and the correct drill, bolts, lock washers for the repair. I feel better and will be attenpting to get er done this weekend. I spent $39.00 for the stuff so I hope it works. I'm tired of seeing the darn hoist hovering over the engine bay! And i'm tired of crawling around underneath it too, sheese.
  10. cometkurt!
    cometkurt! Member
    south paris maine
    jegs sells a engine block crack filler.you pack the hole real tight whait a couple of days
    for it to dry ,then drill it and tap it .it worked wonders on a 289 with the same problem.
    we were imprest!
  11. blugene
    Thanks for the info. Now I know of an alternitive should I have trouble.
  12. blugene
    D_O_N_E !:whew:
    It's only 106 in the shop today, so I was able to tap both left mount holes today and i'm still goin.
    I'll be gettin back to the gas tank project in a few but I wanted to show some pics I took so...
    The engine stand is one of my best investments, I think. $179.00 assembled is what I paid, and it folds up.
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Glad you got that demon behind you.
    Dan
