Strut rod bushing nut!
Discussion in 'General Maverick/Comet' started by ike72com, Feb 16, 2020.
  1. ike72com
    ike72com Member
    Charleston SC
    Strut rod bushing nut got me! I replaced bushing on my other car about 20 years ago. I remembered it being a pain then but i got them off. Guess I was young dum and full of cum then.
    I could leave it alone but would hate taking in to get aligned and young Joe run into same problem.
    Anyone else having problem taking theres off?
  2. rthomas771
    I remember when I changed mine and they didn't fall right off as I planned. BP Blaster, hammer and cold chisel comes to mind.
    ike72com and 71gold like this.
  3. Powerband
    Powerband Member
    NY's \H/
    Simplest solution is to cut off or nut cracker-off nut and replace with new one after cleaning strut threads.
    have fun
    ike72com likes this.
  4. ike72com
    ike72com Member
    Charleston SC
    Great idea!
    And what replacement are those in picture.
  5. ike72com
    ike72com Member
    Charleston SC
    I'm not this far along yet. Still trying to get bar off. Suspect i'm have problems there to. Locked and loaded with your idea!
  6. rthomas771
    Nut came off with impact wrench while strut bar still bolted to lower control arm. If you try a breaker bar you have a good chance of snapping the bar in two. Might want to try and use heat to get nut off. I don't thing a nut cracker will fit into this tight place. The hard part was separating the male/female bushing sleeve
    maverick600 likes this.
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Did you bust the nut on the backside loose? I was fighting mine until I did that, all I was doing was spinning both nuts and the sleeve inside the bushing. with the rear nut loose it came apart easily.
  8. ike72com
    ike72com Member
    Charleston SC
    Sorry guys. Was gonna go give a try but as usual something came up. Wife complained her brakes making funny sound. Yep! Her brakes and serpentine belt got priority!
    71gold likes this.
  9. ike72com
    ike72com Member
    Charleston SC
    I got the nut loosened. I used heat as suggest by rthomas.
    Heat - some pblaster- and more heat.
    I do need to invest in an impact with more balls i discovered.
  10. 71gold
    this time too much could be bad...:yup:
  11. ike72com
    ike72com Member
    Charleston SC
    16 inch breaker got it loose. 6 yr old harbor freight impact just made a bunch of noise.
    Getting a bigger gun tommorrow!
  12. Craig Selvey
    Clean the threads off with a wire brush on a drill, etc.
    Spray with PB Blaster and let soak for a day
    Spray again before hitting it with an impact.
    Easy Peazy. I have yet to ever not make this work, even on old rusty cars
    CA189HJN, mojo and Krazy Comet like this.
  13. Krazy Comet
    Dismal Swamp
    Agreed scrubbing threads on just about any undercarriage bolt will ease removal.
    Usually by time it's forced off without cleaning & lube with impact, the threads are galled badly.
  14. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    In the middle of rebuilding the front end. I had no problem removing the strut nuts, loosened up the rear nut, PB blaster, 30 minutes, 2 beers, One foot wedged against the opposite spindle, a large 1/2 ratchet and 91 quarter turns later did the job. but when I tried to pry the inner and outer sleeves apart the inner sleeves were destroyed. I haven't found a replacement kit that has the inner outer sleeves only ones with just one rod sleeve. Does this make any difference? And any recommendations were to get the best set for her would be appreciated.
  15. Krazy Comet
    Dismal Swamp
    I've never seen inner sleeves that were reusable.
    I use std replacement Moog. Stay away from polyurethane, they can bust the strut rods.
    CaptainComet and TeeEl like this.
