Strut rod bushing nut!
Discussion in 'General Maverick/Comet' started by ike72com, Feb 16, 2020.
  1. ike72com
    ike72com Member
    Charleston SC
    I used moog k8157. Did not have the sleeve. I think new kit is an improved design change.
    K8157 is listed under 70 mustang.
    And yes taking off was a pain. I cleaned reallllllly good and sloobed with antiseze before putting back on.
    Ive not gotten an alignment yet.
  2. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    Great that was my next question as to anyone using a poly set. Thanks Moog it is.
  3. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    Moog K 8157 it is then Thanks
  4. ike72com
    ike72com Member
    Charleston SC
    And if you,re interested in the sleeve version check out rock auto. They list about 5 or 6 version.
    Mobiledreams likes this.
  5. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    Used the Moog Set Still need to find a couple 3/4 16 Jam nuts for the Rod End after tightening down. The ol Maverick got New Upper and lower arms, Springs, spring seats, Stabilizer bar, links and of course the strut rod Bushings. On to the Steering. Thanks
  6. Acornridgeman
    Wisconsin
    Those bushing washers look backwards. They are supposed to cup the rubber. :huh:
    Hotrock and ike72com like this.
  7. ike72com
    ike72com Member
    Charleston SC
    Like this
  8. mojo
    Yep, they are backward! Why do you need jam nuts? Should be able to get nuts at most auto suppliers.
  9. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    IMG_1559.JPG I thought so too. double checked instructions. The washers actually have "This side towards rubber stamped in them. The back side washers are cupped and stamped also and they cup the rubber bushing.
  10. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
  11. Acornridgeman
    Wisconsin
    Well that is interesting. Never ran across ones shaped like that before.
    :cool:
  12. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    I actually put them on that way first. Seemed to make the most sense. This is a Moog k8157 kit and instructions. Where your washers stamped in the metal "this side toward rubber" and "this side toward front" ?
  13. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    Yeah, looks weird, makes me question the instructions and stamping. ike72com has the same Moog kit and his are turned around. He posted a picture and I dont see the stamping on his.
  14. Mobiledreams
    Mobiledreams Member
    Buffalo WV
    1976 Maverick
    You wouldnt happen to have the instructions for your kit or take a look at the ones Ive posted. Are the rear washers on yours cupping the bushing also or just the front ones you show in your photo? I have the larger washers on the back and smaller on the front. They came as one piece (The bushings dont come apart from the washer). Instructions I have are opposite of what I would have done. and the note as to the front of the car may be wrong? Opinion or advice welcome. Might try to see if Moog has support for their products. Thanks
  15. ike72com
    ike72com Member
    Charleston SC
    This is the back side of mine. Just like in attachment.
    Think that washer is glued to the washer.
    2 piece in box.
