Stubborn leaf spring bolt
Discussion in 'Technical' started by Comet4me, Jul 22, 2012.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    We used a cutoff blade on a 5/8 arbor grinder.
  2. Comet4me
    Comet4me Member
    1975 Comet
    Ok thanks everyone, I'll try it.
  3. rthomas771
    Burn it off.
  4. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    I just went through this process. I was having the same problem, ended up taking a bottle jack and lifted the front of the leaf spring underneath where the bolt goes through. Lifting and lowering until the pressure was off and it slid right out. Good luck.
  5. Comet4me
    Comet4me Member
    1975 Comet
    To be clear, my leaf spring is really loose and moving up and down in the eye freely. The bolt head inside the rail pocket rotates 360 when wrenched on (with some effort...doesn't move freely or loosely). Will cutting the bolt on either side of the eye leave the remainder of the bolt stuck within the frame rail or outer bracket?
    @ Alaskamaverick....since my leaf spring is pivoting up and down freely, will the bottle jack method be effective, or is your scenerio based on a ceased leaf?
  6. alaskamaverick
    Spokane, WA
    The way I worked mine. Jack rear of vehicle and place jack stands just forward of the forward leaf spring attach points. Put a floor jack underneath the rear pumpkin, just enough to support it. Remove shocks, brake lines, and rear leaf spring nuts & bolts. Lower jack underneath rear pumpkin and allow tires to touch ground, all weight on tires now. Place small floor jack or bottle jack underneath of front leaf spring at the attachment point. Remove nut from front leaf spring bolt. Raise and lower jack as necessary to remove pressure off of bolt. Push/pull/slide out. Good luck.
  7. Comet4me
    Comet4me Member
    1975 Comet
    Does anybody know what the actual size of those front bolts are supposed to be ?
  8. alaskamaverick
    Spokane, WA
    Did you have to cut them off? I cant remember what size of bolts I got to replace the old ones, I took an old one and matched it up at the hardware store. Grade 8 bolt.
  9. Comet4me
    Comet4me Member
    1975 Comet
    No, not off yet.
  10. alaskamaverick
    Spokane, WA
    darn thing, try putting your tongue on the left side of your mouth ...wish I could be there to help.
  11. blugene
    Can you put the nut on a couple of threads and pry it?
  12. Comet4me
    Comet4me Member
    1975 Comet
    Alaska....wish u could help too
    Blugene...no, but I need to push it out and have no where to pry against.
  13. blugene
    Let me ask this. Is the bolt going in from the outside of the car towards the middle or from the middle of the car out? I will go look at mine in a minute..
  14. blugene
    Ok I just looked and it brought back memories.. I used a block of wood and pryed against the side but mine were not actually seized.. They were stuborn but eventually came out.
  15. blugene
    I am thinking a torch would not be very useful in this area. The bolt is not really gonna get any heat.. Either need to get lucky prying and using penetrant or cut it..
