Stuck drums!!
Discussion in 'Wheels and Tires' started by Damon89, Jul 11, 2019.
  1. Damon89
    Damon89 Member
    Federal way, wa
    1973 Ford maverick
    I have recently acquired a 1973 Ford maverick 4door sedan with 4way drums, the front drums are the original ones I suspect and I've tried everything to get them off, I need to replace the shoes and drums obviously, anyone has advice on how to take the front drums off or should I just give up and take the $500 hit the shop wants to charge me?
    Your input is Much appreciated.
    Thank you.
  2. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Have you tried heating up the center with a torch?
  3. Damon89
    Damon89 Member
    Federal way, wa
    1973 Ford maverick
    No I haven't tried that yet, I will try that. Thanks.
  4. Krazy Comet
    Dismal Swamp
    Assuming wheel nut is removed, heat is just a waste of time and will probably cause other damage. Other than outer bearing seized to spindle, there is NOTHING in center spindle that's going to hold wheel. If wheel somewhat rolls, then the brake shoes are too tight on drum(if they are seized wheel won't roll). There is a star wheel adjustment at bottom of backing plate that allows tightening or loosing of shoes.
    OOPs :oops: I forgot to mention the adjustment is accessible through a opening that should have a rubber plug.
    Auto adj cable on this one is broken.
  5. 71gold
    :Welcome:...:Handshake:
  6. Damon89
    Damon89 Member
    Federal way, wa
    1973 Ford maverick
    Thank you
  7. mojo
    Welcome to forum!:Handshake:
    My opinion! When drums are finally removed; I would consider converting that drum setup to front disk.
    Don't have to worry about adjustments, pulling to one side when wet.
  8. Damon89
    Damon89 Member
    Federal way, wa
    1973 Ford maverick
    I probably will do in the future, thanks for the welcome message.
  9. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Welcome to the forum! Why not unbolt the backing plate, disconnect the brake line and slide the entire assembly off the spindle?
  10. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Tom is correct. Down low on the backing plate is a slot, should have a rubber plug in it. With a screwdriver you can loosen the self adjusting screw.
  11. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Agreed with those who point to loosening the shoe adjustment. A worn out drum which hasn't been resurfaced on a brake lathe will develop a ridge inboard from the shoes. When you try to pull it off the diameter of that ridge can be smaller than the diameter of the shoes, and when it catches the situation will get worse because the shoes will rock on their mounting.
  12. Krazy Comet
    Dismal Swamp
    The picture I posted is of my '69 Fairlane, bought just two weeks ago(exact same brakes on a Maverick). Had a clunk in RF when applying brake so I knew adj was loose, obvious when I found broken cable.
  13. Damon89
    Damon89 Member
    Federal way, wa
    1973 Ford maverick
    Thanks for the Info everyone, and i also tried the adjustment wheel, still no luck. I'm just probably gonna wait a couple weeks and take it to the shop.
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A shop is gonna charge you more than the whole car is worth. If the wheels spin, you can get the drums off with some effort.
    Krazy Comet and 71gold like this.
  15. 71gold
    as Crazy said...if the wheel spins...you (we) are almost there...:smash:
    are both drums doing the same thing?
