sub-frame connectors
Discussion in 'Technical' started by David74maverick, Apr 1, 2005.
  1. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    connectors
    You need them welded on with the car setting on it's on wheels. Otherwise the body will flex differently depending on the weight being supported by the wheels or on stands on the frame. Same effect as if you tighten the bolts on your lower and upper A-arms with the wheels in the air or on the ground. Preloads the suspension differently.
  2. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Common wisdom says to do it with the tires on the ground, but I don't think it matters too much as long as the frames not twisted.
    When you weld, the cleaner the metal the easier it is. I wouldn't worry about them falling off unless you do a totally horrible job at welding. It will probably look ugly, but should still be strong. Those wire feeds work good on thick metal like subframe connectors, not so good on the thin stuff like body sheetmetal. They produce a lot of heat. Make sure to remove the carpet or you might have a fire.
  3. big_fordsrule
    big_fordsrule Member
    Jackson Oh
    '73 Maverick
    Where did you get these connectors?? I might have to have some:D
  4. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I forget who I got theme from but the guy was refered to me on this or another message board... it's been awhile.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    If they are the square tubing. Working off memory here; like 2 1/2 inch by 1/2 or 3/4 inch. They might be the ones Rudy Bidlack is selling. If anyone is interested I can give his e-mail addy......:hmmm: OR you could join the MCCI and read his classified in the bi-monthly newsletter! :D
  6. big_fordsrule
    Jackson Oh
    '73 Maverick
    I need to Join anyways, Is it the form in the back of my Autokrafters catalog?
    :bananaman :bananaman :bananaman :bananaman
  7. Craig Selvey
    Yes it is.
  8. don graham
    i got my frame connectors from summit racing. there not in there catalog. you have to call and ask for them. about $125.:)
  9. stmanser
    Davenport, Iowa
    ok when you weld up the subframe connectors....they mount to the forward leaf spring bolt correct?
    and then they weld to where at on the frame?
    and will the traction bars get in the way of the subframe connectors?
    thanks
    just something i was wondering
