Subframe connectors
Discussion in 'Technical' started by Quannah74, Jan 24, 2016.
  1. Quannah74
    Quannah74 Member
    Billings mt
    Ford maverick 74
    Wielded or bolt on, looked at a few articles but still can't decide. Any body have experience?
  2. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Welding is superior if you weld them in correctly with good penetration.
    71gold and Crazy Larry like this.
  3. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    I would say weld them Thats what I am going to do If your not comfortable welding then pay someone to do it right
    You will need to make sure you get good penetration for it to last
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    If you want to achieve the full benefit, weld them. I use Competition Engineering weld ons.
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Weld on, but that thin frame metal is easy to burn through.
    The parking brake cable can be a PIA. If I were to do it again, I would look for a way to clearance for the cable.
    I wanted to also use Traction Master bars which attached at the same point as the sub-frame connectors. To do so, I built a box section. This also allowed the connectors to remain parallel.
    Micah
  6. Quannah74
    Quannah74 Member
    Billings mt
    Ford maverick 74
    Traction master bars are bolt ons right
  7. 71Mavrk
    71Mavrk Member
    Nevada
  8. Cruzin Illusion
    1972 Grabber
