Subtle 74 Maverick
Average User Rating:
5/5,
Ownership Satus:
Currently own it
Year:
1974
Engine:
351 - 8 cylinder
Color:
bronze
  1. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    This intake set up is costing more than I was planning for. I had to cut costs and install a stock set of 5.8 f150 exhaust manifolds I have, just flipped sides. Lots of room for the turbo up front with minimal accessories. 20180118_1741571.jpg
  2. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    I got my transmission cooler installed while waiting for parts. 20180123_1745341.jpg
  3. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    I like the way you think. That thing is going to be epic.
  4. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    I made a little more progress and successfully can close the hood now. I cleaned up the top flange on my Edelbrock low profile elbow and installed a few boost ports, had to use their fuel rails as well. The good news is all this fits under the stock hood. Now the tb won't clear in it's factory orientation I may have to rotate it as shown.
    20180131_1640291.jpg 20180203_1429422.jpg 20180203_1430513.jpg 20180203_1431044.jpg
    Krazy Comet likes this.
  5. yellow75
    Tillamook Oregon
    Interesting, my knowledge of how turbos work and what all is needed to make it all work is limited so I will be watching and learning. What compression ratio are you running , what size turbo are you putting on it, what increase in power can you gain from using better flowing exhaust manifolds ( headers) how are you controlling ignition timing. Cant wait to see how it all gets plumbed in
  6. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    I had this set up in my previous car, except prior I was using the on3 headers and making 480rwhp on 10psi with a small on3 76/65 turbo. I will be using the on3 cold side, but have to redo the hotside to get my turbo on the drivers side. I am just using a stock mustang a9l computer and stock ignition system. The turbo this time will be an on3 78/75 and I still plan to run 10 psi on pump gas as without a bar 11.5 is all I can run anyway. The 351w is stock with I think around 8.8 compression and cast pistons right out of a 95 f150
  7. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    Is this setup expected to make more than 480 rwhp?
  8. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    I suspect the turbo upgrade will free up some hp as the 76/65 I had on prior was struggling starting at 5500 rpm and that's where I was shifting because of it. Hopefully I am over 500 rwhp with the new 78/75 turbo at the same 10psi boost. I will always be able to up the boost and add methanal injection if I want more, although I have a 700rwhp fox for that. My intent was for a budget build on the Maverick, but with the aje setup I kinda missed that target. How much hp are you putting down to run an 11.49?
    tbirdz12 likes this.
  9. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    480 rwhp. I was wondering if the turbo route would end up cheaper than an NA setup
  10. BenjaminJR
    BenjaminJR Member
    Yucca Valley, CA
    1972 Ford Maverick Grabber
    Hello I'm looking at installing a turbocharger into my 72 Ford Maverick 302, would this setup work for that engine?
  11. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    It's looking like the on3 cold side will work out after trimming a couple pieces. I will be making my own hotside as the on3 hotside places the turbo where the battery is, I don't think it would fit anyway, even if I relocated the battery. For a 302, I would think a set of bbk short header flipped would work nice or even stock mustang headers if you don't want to use the stock Maverick ones that is. I don't know of a prefab turbo kit myself but I'm new to Mavericks
  12. bmcdaniel
    There are a couple companies that makes a turbo setup where the turbo mounts in the back of the car. Then there are just two tubes that run to the engine.
  13. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    I like all the extra room with those shock towers so how do you like the aje suspension? Ive heard weld quality is not so great but man it sure opens things up & its got to be lighter
  14. buickv6
    buickv6 Member
    Canada
    1974 Maverick
    I find the AJE products a great value for the cost. There is a little weld splatter and no its maybe not perfection, but great weld penetration and strength which is most important to me. Have a look at this... maverick build 035.JPG
  15. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    Looks good to me ill most likely go that route in the future when finances allow
